Hello #2760831
04/06/20 05:10 PM
04/06/20 05:10 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
My leftover 3 in exhaust pipe flagpole, and the Charger got to escape out of the garage, I hope and pray that everybody is doing okay during this crazy BS, love Y'all from Katy Texas,Tacks are also closed down here , DYING to test the longer Ram tubes, GRRRRRRRRRRR
Re: Hello [Re: CSK] #2761007
04/07/20 08:41 AM
04/07/20 08:41 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
up penguin
Re: Hello [Re: CSK] #2761095
04/07/20 12:52 PM
04/07/20 12:52 PM
moparx Offline
moparx  Offline
great pic ! bow
slow work on my charger, but i have the front mounted radiator and ac condenser deal finished.
had to start yard work yesterday so i can stay ahead of the stuff needing cleaned out before it greens up.
so far, everything here is good health wise.
beer
Re: Hello [Re: moparx] #2761220
04/07/20 06:47 PM
04/07/20 06:47 PM
Alberta
440_Offroader Offline
Alberta
Awesome picture! Classic Americana... Cool Mopar with an American flag in the background. I wish I had a fast car that I couldn't take to a track! Lol
Re: Hello [Re: 440_Offroader] #2761324
04/07/20 11:46 PM
04/07/20 11:46 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Dig it!! beer from the PNW
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Hello [Re: Stroker Scamp] #2761557
04/08/20 04:16 PM
04/08/20 04:16 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Me & the Charger "Brain Damage" escaped again, doing some low RPM data logging tuning
Re: Hello [Re: CSK] #2761680
04/08/20 08:02 PM
04/08/20 08:02 PM
Have you tried leaning down the AFR to 14.8 to 15.5 at light part throttle cruise at or under 2500 RPM yet?
What altitude, outside air temps and normal humidity are you driving in in usually?
If not, maybe you should twocents
Re: Hello [Re: Cab_Burge] #2761706
04/08/20 08:58 PM
04/08/20 08:58 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Apr 08 3:00 pm
85 deg F
85%
29.82 Hg
80 deg F
156.1
SW 8 mph
91.79 %
2902 ft.
Most the time it is 95-106 deg, 95% humidity, if I lean it out much more that it is it does not like it.
Re: Hello [Re: CSK] #2761730
04/08/20 09:43 PM
04/08/20 09:43 PM
Man, I can't imagine that much humidity now except when it is raining here shock shruggy
I'm glad you have tried leaner AFR also up
The moisture in the air does turn to steam inside the combustion chambers, correct work
Water molecules in real humid air displace the oxygen molecules in it making it real hard to make big power when it is humid, no matter what the outside air temps. are, altitude is or barometric pressures are whiney
I'm not sure that all wide ban systems read exactly the same either, just like tire pressure gauges do shruggy
Re: Hello [Re: Cab_Burge] #2761924
04/09/20 01:52 PM
04/09/20 01:52 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Are those dust covers on your injection stacks? If so,did you forget to take them before taking the car out.
Re: Hello [Re: OUTLAWSSAA] #2761945
04/09/20 02:58 PM
04/09/20 02:58 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
They are Water repellent Pre Filters.
