E-body rear window louver install questions
#2760661
04/06/20 10:03 AM
04/06/20 10:03 AM
Posts: 4,049 Connecticut
jeff968
Connecticut
Hi, installing a set of louvers on the T/A and I have 3 questions:
1) Does the lanyard screw install on the inner louver support or the outer? This is for the lanyard that holds the pin clip. 2) Does the gasket on the pin install inside the trunk compartment or outside on the exterior? 3) How should they fit when installed? Should they be snug or tight against the roof? Trying to determine how much PIN should be exposed.
Thanks!
1970 Dodge Challenger T/A
Re: E-body rear window louver install questions
[Re: spk2go]
#2761018
04/07/20 09:12 AM
04/07/20 09:12 AM
jeff968
Connecticut
If I remember correctly, Challengers and Cudas louvers are different. Challenger louvers will fit OK on a Cuda, but Cuda louvers will fit poorly on a Challenger. Ha, someone would do that? I have Challenger louvers on my Challenger. The questions I have above would apply to both kinds. Still wonder how tight they should be against the car. The Pins can be adjusted for the snugness. Thx
