Tail lamp wiring / brightness issue
#2760927
04/06/20 10:22 PM
04/06/20 10:22 PM
Posts: 707 California
BigDaddy440
California
I have all new wiring in my 69 Roadrunner, and I'm getting it all installed and dialed in. So far everything works, except the horn but I have a concern about the tail lights.
I noticed that the filament that lights up when the running-lights are on is extremely bright and the brake light / blinker filament in the bulb is fairly dim in comparison. I'm pretty sure it supposed to be the opposite. Is there an easy fix? Did I mix up the signal somehow? Everything is "plug and play" so I'm not sure where I may have made a mistake.
Is it possible the issue may be in the steering column wiring? I matched the colors coming from the steering column (rebuilt and rewired professionally) to the new under-dash wiring harness. Not only do I have this brightness reversal issue, but my horn doesn't work. Although if send 12 volts to the right wire in the harness the horn is activated.
Just thought I'd throw this out and see if anyone has a possible solution or suggestion.
Thanks! -Dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Tail lamp wiring / brightness issue
[Re: BigDaddy440]
#2760950
04/06/20 11:55 PM
04/06/20 11:55 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sounds like the "brake/turn" and "running light" wires were reversed somewhere in the harness. Or bulbs installed backwards which should be difficult to do without damaging something. Easy fix right at the socket if that's the case.
Definitely check the circuits with a test light. Looks like all the rear running light circuit wiring is black. They originate as a single wire running to the rear of the car before branching off to the individual lamps. Right turn/brake light is brown. Left turn/brake is dark green. If it was crossed up further forward, all the running lights on the rear should also be not right. All this stuff runs through an 8 pin connector behind the left kick panel.
3 wires run it all. Both sides doing the same thing? Front turns OK? Tag light OK?
The black wire on the horn relay runs through the bulkhead to the turn signal switch connector and should go to ground when the horn is pushed. That can be checked with a test light. It should also blow the horns when a ground source is touched to that pin on the relay. Constant 12v needed on the other pin.
[Re: CMcAllister]
#2761004
04/07/20 08:16 AM
04/07/20 08:16 AM
RapidRobert
Sounds like the "brake/turn" and "running light" wires were reversed somewhere in the harness. X2
[Re: RapidRobert]
#2763258
04/13/20 02:21 AM
04/13/20 02:21 AM
BigDaddy440
California
Just wanted to post an update. I took a closer look at the tail lamp bulb sockets. Keep in mind this is a new harness. I was able to turn the round contact disk inside the sockets with a small screw driver which effectively reverses the signal to the bulbs (which only fit in one direction) -problem solved. I think the harness manufacturer installed the contact disk backwards, but it's a super simple fix. Thank you for the suggestions, it helped solve the issue!
[Re: Sniper]
#2763918
04/14/20 04:17 PM
04/14/20 04:17 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Wrong bulbs can also do that, I believe you should have 1157 bulbs in there, if so then it's fixed. And 2157's are a bit brighter.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2764047
04/14/20 11:53 PM
04/14/20 11:53 PM
BigDaddy440
California
Wrong bulbs can also do that, I believe you should have 1157 bulbs in there, if so then it's fixed. And 2157's are a bit brighter. Thanks guys. I do believe they are 1157s.
