What is this metal canister hooked to vacuum advance? #2760432
04/05/20 04:28 PM
04/05/20 04:28 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Is this an air flow sensor?
There is an electrical connection.
One side connected to vacuum advance, the other the front vacuum port next to the DS idle mixture screw.
There is another connection on it, but l have it plugged.
Didn't seem to make a difference plugged or not.
Is it supposed to be connected somewhere?
71 340 application
Mopar
Or
No
Car
Re: What is this metal canister hooked to vacuum advance? [Re: MONC] #2760434
04/05/20 04:34 PM
04/05/20 04:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: What is this metal canister hooked to vacuum advance? [Re: MONC] #2760474
04/05/20 05:59 PM
04/05/20 05:59 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I believe it to be a retard mechanism. I haven't seen one on a small block but on big blocks in the early '70's. I believe it prevents vacuum advance in 1st and 2nd gear for emission purposes. At least that's how GM approached it those days, GM called it TCS, or transmission controlled spark. Theirs was easy to bypass, just bypass the solenoid with a piece of vacuum tube.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: What is this metal canister hooked to vacuum advance? [Re: 3hundred] #2760625
04/06/20 07:43 AM
04/06/20 07:43 AM
MONC Offline OP
MONC  Offline OP
Thanks for the replies, and the link Barry.
Yes it is a CA car from my knowledge.
I did try bypassing it. Didn't seem to make a difference at idle.
Am trying to get the car tuned properly, and going through all the connections.
I will likely keep it bypassed , to eliminate variables.
Mopar
Or
No
Car
