EFI Fuel Tank Sending Units #2760085
04/04/20 05:56 PM
04/04/20 05:56 PM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
With the bit of extra time some of have these days, I've been looking into EFI. With the various EFI fuel tank kits available out there, Spectra, Tanks,Inc, Holley and Aeromotive, how good are the fuel level sending units in these? I searched a bit and didn't find much. I know the repro units for the stock fuel tanks get a bad wrap. Am I going to have fuel level issues buying into an EFI fuel tank kit? I've been known to run the fuel level a bit low, especially at the end of the Chicago cruising season.
1972 Dodge Challenger
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760096
04/04/20 06:20 PM
04/04/20 06:20 PM
AndyF Online content
AndyF  Online Content
I would assume they are the same reproduction sending units that everyone else uses. I don't know why someone like Tanks Inc. would tool up a special sending unit for their EFI tanks. You could call and ask but I bet they'll tell you they use the same sending unit in both types of tanks.
Re: EFI Fuel Tank Sending Units [Re: AndyF] #2760101
04/04/20 06:35 PM
04/04/20 06:35 PM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
I have read that Rick's custom tanks only uses the tube style sending units. Their stuff looks to be top notch. Probably a bit more than I need. Tanks Inc seems to have the same sending unit. While I was hoping to find a complete kit. I suppose I could run with the Tank's inc tank and tube sending unit then find a fuel pump from some place else. Many on Moparts have the Jake Fab fuel puck and a pump below that. He doesn't seem to be in business anymore as the website is gone.
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760111
04/04/20 06:52 PM
04/04/20 06:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the Tanks Inc set up works great, the sending unit is nothing like the OEM set up. 68 Charger they specify one for mopars Ohms gauge
Re: EFI Fuel Tank Sending Units [Re: CSK] #2760113
04/04/20 06:59 PM
04/04/20 06:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The fuel level sender is on the left, you can see it is nothing like the oem.
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760131
04/04/20 07:39 PM
04/04/20 07:39 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think this setup just came out recently. If you aren't driving too crazy on a low tank, it should work out okay. I would expect the sending unit to be pretty decent coming out of Holley
https://www.holley.com/products/fue...uel_pumps/efi_in-tank_pumps/parts/12-318
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: EFI Fuel Tank Sending Units [Re: GoodysGotaCuda] #2760134
04/04/20 07:46 PM
04/04/20 07:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
"no separate return line is required because this module returns excess fuel right inside the tank!"
Wonder if there might be any vapor lock or fuel heating issues ? At 65 PSI i wouldn't think vapor lock would be an issue but the heated fuel sitting in the engine bay might cause some other unknown problems ? shruggy beer
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760141
04/04/20 08:03 PM
04/04/20 08:03 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I run a surge tank set-up with a stock tank and a modified factory style pick-up/sending unit. The benefit of this system is that it will run hard even on a road course without introducing any air into the high pressure side of the system even when the tank is down to the last gallon or two.
The low pressure side circulates fuel at near 0 psi from the tank to the surge tank and back into the tank, and the high pressure side circulates fuel from the surge tank through the fuel rails, through the pressure regulator and back into the surge tank. It is very effective especially if you run below half a tank and are doing some spirited driving.
Re: EFI Fuel Tank Sending Units [Re: TJP] #2760144
04/04/20 08:13 PM
04/04/20 08:13 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Any new Dodge Hemi doesn't have a return line, at least that I am aware of. They PWM the fuel pump to provide adequate pressure at the rail, but the fuel is not in constant circulation.
That said, my car has an external regulator which is very close to the tank and works very similarly. I haven't had any issues.
2020 RAM 1500
Re: EFI Fuel Tank Sending Units [Re: GoodysGotaCuda] #2760146
04/04/20 08:15 PM
04/04/20 08:15 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
If it works this looks like a nice direct replacement setup for those of us who have already gone through our factory fuel system with new tank, fuel lines, etc.
It looks like Holley is building these for a variety of cars.
Anyone tried one yet?
Re: EFI Fuel Tank Sending Units [Re: jbc426] #2760152
04/04/20 08:35 PM
04/04/20 08:35 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I used the universal, float-less sender from Tanks.inc in my '70 Challenger Sniper EFI set up. Works perfectly. Hooks up with original wire. Jeff
Re: EFI Fuel Tank Sending Units [Re: TJP] #2760164
04/04/20 09:06 PM
04/04/20 09:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Doubtful, because with EFI fuel is always moving, a carb doesn't have fuel continuously moving due to the float setup.
Re: EFI Fuel Tank Sending Units [Re: Sniper] #2760167
04/04/20 09:15 PM
04/04/20 09:15 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The setup he was referring to has the regulator in the fuel tank. Therefore the only fuel really "moving" while stopped is what is being bypassed in the tank and what is at the injector. Not much between the tank and the injector.
2020 RAM 1500
Re: EFI Fuel Tank Sending Units [Re: 1969RR] #2760182
04/04/20 09:48 PM
04/04/20 09:48 PM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
1969RR how do you like that Holley Sniper and fuel tank set up in your Challenger? Where are you running the vent line to?
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760188
04/04/20 10:07 PM
04/04/20 10:07 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Aeromotive make real tank w/pump in it
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760749
04/06/20 01:33 PM
04/06/20 01:33 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello Plum72, I really like the way the system went in. Tank was easy bolt-in. Used 6AN feed and return to the tank. For the vent, I ran the hose and alumn fuel line up thru the trunk fill tube grommet. I just drilled a hole to fit the alumn line. Then ran the alumn line up next to the fill tube and attached the roll-over valve right next to the top of the fill tube. Easy to do. You're supposed to have the roll-over valve as high in the system as possible. Let me know if I can help you in any way. Take care, Jeff
Re: EFI Fuel Tank Sending Units [Re: PLUM_72] #2760755
04/06/20 01:45 PM
04/06/20 01:45 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Knew I had a pic somewhere! Sorry it's sideways!
Re: EFI Fuel Tank Sending Units [Re: GoodysGotaCuda] #2760780
04/06/20 03:07 PM
04/06/20 03:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Plenty of these systems on the road, you don't hear about issues with an in tank regulator setup causes vapor lock or fuel heating issues. Lot's of other things to worry about, don't think this is on that list.
Re: EFI Fuel Tank Sending Units [Re: CSK] #2760783
04/06/20 03:35 PM
04/06/20 03:35 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
The regular float style Tanks in sends works fine, no problems so far after 2-3 years. I WOULD absolutely test it before you install I had to send a few back because the ohm readings were off at full and empty. That floatless one sounds like an even better deal if it is accurate.
Re: EFI Fuel Tank Sending Units [Re: KillerBee] #2791907
07/02/20 12:30 PM
07/02/20 12:30 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
BUMP
I too am curious if anyone has used the Holley 12-318 Pump/Sending Unit assembly.
I just read that the Sniper requires a return line but this new assembly does not have a return line built in. Can someone confirm if this unit would work without the return with the Sniper?
