On a SB is there a Gasket on the Oil
#2760069
04/04/20 05:35 PM
04/04/20 05:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On a SB at the block where the filter is you have the plate there that has the bolt to the mount plate for the filter.. my question is.. is there a gasket on the block side at the mount bolt... I cant remember... I'm in the house and dont have my book with me
Re: On a SB is there a Gasket on the Oil
[Re: MR_P_BODY]
#2760084
04/04/20 05:53 PM
04/04/20 05:53 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Mr P , are you talking about the bolt with the 3/8 square in the center to mount the plate on ? if so that bolt don't use a washer.
6.50 @105.26
[Re: Kindafast]
#2760094
04/04/20 06:17 PM
04/04/20 06:17 PM
MR_P_BODY
I didnt think there was but I have a Superformance 90* gasket set and it has the large outer gasket then 2 for the center bolt.. one is cork and the other is hard gasket... so you guys are saying no gasket at all on that center bolt
[Re: MR_P_BODY]
#2760130
04/04/20 07:37 PM
04/04/20 07:37 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I think you will find that the plate will have a gap under the bolt hole when the outter 4 inch gasket is in place. I think the plate will act like a spring. For that reason I always have put a fiber gasket under the bolt hole too if I use a hollow bolt withe a nut head to tighten it down...
Iffylube did an oil change on my 65 Bcuda and pulled my 90 degree adapter sideways and that broke the seal and the center bolt unspun. Made it 5 miles down the road when the back tires spun out in a corner and my IDIOT light came on.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: MR_P_BODY]
#2760384
04/05/20 01:32 PM
04/05/20 01:32 PM
RapidRobert
then 2 for the center bolt.. one is cork and the other is hard gasket. On a side note (for a 90 deg adapter) you want the cork one inside on the center bolt & the hard one under the bolt head outside the adapter
[Re: dodger mope]
#2760407
04/05/20 02:55 PM
04/05/20 02:55 PM
MR_P_BODY
Does anyone know the thickness of the large outer gasket.. I think this is the problem point.. the one I have is about 3/16" thick and when I put the plate on I think it can/is bowing the plate I tried the thin small gasket and it was less of a leak but still leaked.. I will have to check to see if I have a thinner large gasket more like the superformance one
[Re: dodger mope]
#2760470
04/05/20 05:50 PM
04/05/20 05:50 PM
Dave_J
Auburn WA
I like that one but $70 plus Hughes shipping rate..... I made my own from a stock magnum one. I do use the thicker Felpro large outter gasket with a smeer of RTV and the fiber one under the bolt area. The 6 holes are drilled out to 3/8 inch. The center of the bolt is also drilled to 1/2 inch inside.
[Re: MR_P_BODY]
#2760495
04/05/20 07:07 PM
04/05/20 07:07 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It should have to deflect the plate some when the center stud is tightened to ensure pressure on the outer gasket. Stack gaskets under the center and it takes pressure off of the outer ring.
I've never seen a gasket used under the center of the plate - a small leak there is meaningless - and the outer rings are at least .150" thick. A smear of silicone on the center block boss should be adequate to seal that joint if it's a concern.
[Re: CMcAllister]
#2760773
04/06/20 02:49 PM
04/06/20 02:49 PM
MR_P_BODY
This block looks to be machine deeper than most(in the filter area) I had to stack up 2 of the outer gaskets and it JUST does have a couple thousands compression on the plate.. I think it should have more compression on it but I will try it
[Re: MR_P_BODY]
#2760799
04/06/20 04:15 PM
04/06/20 04:15 PM
Dave_J
Auburn WA
Using a used outter plate gasket, when I put my 4 hole Commando plate on the new Magnum 5.9 block there was about 0.055 gap (stacked feeler gauges) from the plate to the iron thread hump. The Magnum 6 hole plate had about a 0.040 gap. That is a huge gap and I don't think the hollow stud will compress the gasket enough to get the steel to touch iron. I did use a used Magnum plate gasket. There will not be enough of an internal oil leak due to the threads sealing. I just know if the steel plate is not touching the iron block, then the plate is in compression and the hollow stud may work loose. You want the hollow stud to be 'STRETCH' of torque so it can not come loose.
[Re: MR_P_BODY]
#2760805
04/06/20 04:28 PM
04/06/20 04:28 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I just measured the compressed thickness of the large outer gasket that came off an old 340 block with a plate. .075". Laying the filter plate block side down on a flat surface and measuring the distance from the center filter stud surface to the flat is about .110".
Checking the filter area on an old X block, the center attachment boss is approx. .080 higher than the outer gasket surface. Setting the plate on the bare block confirms the center boss is higher than the outer gasket surface.
This is just a few quick checks with some parts I have handy. Stacking any gaskets under center of the plate is asking for the outer gasket to leak based on what I see, Again, a smear of silicone is all I would chance using on the center of the plate.
Your parts may be different, but the fits can be checked with what you are using.
ETA... Just checked a second plate and it is substantially different - maybe .100" more offset center to outer surfaces. So, not all plates are the same. Ultimately the parts you have and how the block is machined will determine how you assemble yours. I would want a good crush on that outer gasket when done.
