Re: Brake Fluid question. DOT 5? [Re: CMcAllister] #2761724
04/08/20 09:34 PM
04/08/20 09:34 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
5.1 has a higher boiling point than silicone too.
Re: Brake Fluid question. DOT 5? [Re: dthemi] #2761898
04/09/20 12:52 PM
04/09/20 12:52 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
i found this info in my documents-----
Brake fluid is engineered to do specific things in specific ways. So it's important to put the right kind in your car or truck.
DOT 3 and DOT 4 brake fluids are glycol-based. They're used in most modern cars and trucks, because they work with ABS brakes. DOT 4 has a higher boiling point than DOT 3. You can use DOT 4 where DOT 3 is called for, but not the reverse. Using DOT 3 in a DOT 4 brake risks boiling the brake fluid. Glycol-based fluid can absorb water over time, which leads to corrosion. It also changes the quality of the fluid in braking. This is one reason to have your brake fluid changed regularly.
DOT 5 is silicone-based. Its advantage is that it doesn't absorb water, so it doesn't corrode brake systems. However, it doesn't work with ABS brakes. So it's mostly for older cars and trucks.
Re: Brake Fluid question. DOT 5? [Re: dodger mope] #2762280
04/10/20 12:26 PM
04/10/20 12:26 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I saw a video of dot 5 swelling seals is that true.? That's the only reason I have been hesitant to use it.
Re: Brake Fluid question. DOT 5? [Re: B1MAXX] #2763184
04/12/20 08:24 PM
04/12/20 08:24 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I totally understand the paint issue, but as long as you don't use a squirt pistol to add fluid I would just be careful. Talk to strange, mark williams, or wilwood they all recommend 5.1.
Re: Brake Fluid question. DOT 5? [Re: dthemi] #2763195
04/12/20 08:47 PM
04/12/20 08:47 PM
katakan
lilred Offline
lilred  Offline
katakan
I have been using Dot 5 in my all cars for at least 30 years, have it my '70 Roadrunner that is in that 30 year range, drained some at all the 4 corners a few years ago and it still had a bit of that purple look to it. The reason I went to Dot 5 30 some years ago is that after 2-3 years of Dot 3 fluid I was having brake leakage from the wheel cyls due to rusty bores, I live where we have that good old white crap, in the snow belt for 1/2 a year. Not to mention it doesn't destroy your paint!!!I I also have it in different year Vipers, '02, '03 with ABS and no problems.
Re: Brake Fluid question. DOT 5? [Re: B1MAXX] #2763295
04/13/20 08:34 AM
04/13/20 08:34 AM
Minn
SportF Offline
SportF  Offline
Minn
If this was true then that means it would/could cause brake failures. Can you imagine the legal liability for someone selling a product, that if misused, could kill you?
What is interesting about this whole question is that when this came up 10 years ago or more, the majority said don't use it. Its good to see "we" have become more informed.
Re: Brake Fluid question. DOT 5? [Re: SportF] #2763342
04/13/20 10:10 AM
04/13/20 10:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
some years back I saw or read something about dot 5 swelling seals/rubber stuff. i'd been using dot 5 on one of my cars for several years and thought i'd better check this out. it was complete bunk. no damage and everything was as good as the day it was installed. I don't understand the anti dot 5 thing. I probably have close to 25yrs on the brake system with dot 5 and the car has never stopped better.
Re: Brake Fluid question. DOT 5? [Re: lewtot184] #2763395
04/13/20 12:14 PM
04/13/20 12:14 PM
Apollo, PA.
Apollo, PA.
The reason I have wanted to do this was I have a charger and belvedere that sit for long periods and i have had rusty seepage from the master cylinder pushrod area that eventually eats all my firewall paint below the master. If this would stop that it would be great! boogie
Re: Brake Fluid question. DOT 5? [Re: B1MAXX] #2763458
04/13/20 01:37 PM
04/13/20 01:37 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
go for it. your reasoning is the same as mine. both my cars are fine with dot 5.
Re: Brake Fluid question. DOT 5? [Re: lewtot184] #2763833
04/14/20 12:28 PM
04/14/20 12:28 PM
Apollo, PA.
Apollo, PA.
So just drain as best I can and refill?
Re: Brake Fluid question. DOT 5? [Re: B1MAXX] #2763839
04/14/20 12:40 PM
04/14/20 12:40 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you need to flush the dot 3 out. dot3 and dot 5 are not compatible. when I switched over I took the master cylinder, distribution block and wheel cylinders apart and cleaned all the dot 3 off/out of them. I took a couple cans of brake cleaner and flushed all the lines. it's a little work but not difficult.
Re: Brake Fluid question. DOT 5? [Re: lewtot184] #2763991
04/14/20 08:26 PM
04/14/20 08:26 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
DOT 3/4 and DOT 5 are not miscible. But they do not react with each other. The glycol and the silicone oil will form two separate layers if mixed. That's all.
You want to get all the glycol out that you can, only because any that is left will gradually attract water and cause corrosion where it sits.
DOT 3 & 4 also have a lower boiling point than 5, so any glycol left in the system will boil first twocents
