05 Town&Country climate control problem #275998
04/03/09 02:39 PM
04/03/09 02:39 PM
central PA
mopartial Offline OP
central PA
Control will not send air to DEF or FEET or MIX. Blows straight out dash vents at all settings. My old T&C did the same thing till it got totalled. Any thoughts?
If that control has to be changed, how does it come outta there?
Thanks.
If it aint broke, dont break it.
Re: 05 Town&Country climate control problem [Re: mopartial] #275999
04/03/09 10:41 PM
04/03/09 10:41 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
sounds like the bcm is bugging out...try disconnecting the battery to reboot it...
Re: 05 Town&Country climate control problem [Re: AARCONV] #276000
04/04/09 12:13 AM
04/04/09 12:13 AM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Try unhooking batt for at least 10min or unhook and touch cables together. If this does not work sounds like broken heater door.
Re: 05 Town&Country climate control problem [Re: mod381] #276001
04/05/09 12:01 PM
04/05/09 12:01 PM
central PA
central PA
It worked!!! Easiest repair I have ever done!
Who says cars with computers are hard to work on?
Thanks again.
