Updates during this Quarantine
#2759782
04/04/20 11:18 AM
04/04/20 11:18 AM
Posts: 4,670 On the parachute mount
n20mstr
Someone at my job had the virus (He is OK and recovered). Ive been quarantined for the last two weeks. Took 97lbs off my car. Re wired to fix a lot of my "mistakes" lol I updated to a Go Lithium battery and to say it spins the engine is an understatement. With the ignition on it spins like it has no plugs in it. Today would have been the first Street Car Shootout at Cecil county. HOPEFULLY this virus is done? in a month or? and we can all get back to racing, and hopefully some new best ET's !!
Stay Safe Everyone
....BAD A$$ STREET CAR.....
Re: Updates during this Quarantine
[Re: n20mstr]
#2759787
04/04/20 11:43 AM
04/04/20 11:43 AM
Posts: 2,491 PA
moparacer
PA
Good to hear you seem to be OK concerning the virus crap. I am not on quarantine but I am using the extra time to rewire my car too after I set the engine back, made new headers and am swapping the front suspension out.
I am considering going to 16V now too since I am into the wiring.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: n20mstr]
#2759800
04/04/20 12:25 PM
04/04/20 12:25 PM
Posts: 19,307 north of coder
moparx
Stay Safe Everyone
do you have a link, and is this battery way smaller ? also, what are you using for a charger ? TIA.
[Re: moparx]
#2761103
04/07/20 01:21 PM
04/07/20 01:21 PM
n20mstr
Stay Safe Everyone
do you have a link, and is this battery way smaller ? also, what are you using for a charger ? TIA. Just google "go lithium" or look them up on facebook. THey have their own charger.
[Re: n20mstr]
#2761107
04/07/20 01:25 PM
04/07/20 01:25 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: n20mstr]
#2761459
04/08/20 11:56 AM
04/08/20 11:56 AM
moparx
Stay Safe Everyone
do you have a link, and is this battery way smaller ? also, what are you using for a charger ? TIA. Just google "go lithium" or look them up on facebook. THey have their own charger. i did that. i didn't realize it was a 16v. i'm not ready to commit to that. thanks anyway.
[Re: moparx]
#2761516
04/08/20 02:28 PM
04/08/20 02:28 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
We use a Go Lithium in our dragster and my car has a Lithium Pros battery in it. They work better than anything I have ever used and weigh next to nothing. Good to hear you are using your time to take out some weight. Best HP gain you will ever find
[Re: moparx]
#2761895
04/09/20 12:35 PM
04/09/20 12:35 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
weight is certainly an issue ! too bad the infolink debacle made lee and the weight thread disappear. in my case, i remove weight, but i still have to install subframe connectors with provisions to attach a roll bar if the engine makes enough steam to get me under 11.49. [ ] i'll be looking for more places to hack excess. This one? https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2246442/1.html
[Re: hemi-itis]
#2762217
04/10/20 10:20 AM
04/10/20 10:20 AM
n20mstr
Care to share share where 100 was taken?? Us heavy weights want to know! Battery 42.0 battery tray 4.0 Alternator and brackets 12.0 Pass seat 17.0 ballast in trunk 15.0 2gals fuel 14.0 wire 18.0 It adds up to over 100, but I also put some back in, new battery and wiring On the subject of wiring, Voltage drops at the fuel pump and fan water pump are .20 volts, 1.2% Im going to check the voltage drop at the starter, the new wiring there was a huge improvement . I spent a lot of time re sizing wires, some up, some down. DOwnsizing saves a lot of weight. I changed the wire from the dist block to the fans/water pump and save 1/2lb on just one 5' length of wire !
[Re: pittsburghracer]
#2762301
04/10/20 01:15 PM
04/10/20 01:15 PM
moparx
weight is certainly an issue ! too bad the infolink debacle made lee and the weight thread disappear. in my case, i remove weight, but i still have to install subframe connectors with provisions to attach a roll bar if the engine makes enough steam to get me under 11.49. [ ] i'll be looking for more places to hack excess. This one? https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2246442/1.html yes, that's it ! when FMJ [lee] had a bunch of issues, he bailed and the thread just disappeared after a while. it needs to come back.
