'00 Dakota 5.9- no ground pulse to injectors UPDATE
#2759457
04/03/20 01:02 PM
04/03/20 01:02 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
So I finally had the truck towed home so I have more time to play with it. New cam sensor (pickup coil), new crank sensor, new fuel pump. Will run if you dribble gas into throttle body (neighbors probably not too happy with no exhaust ). Has 50 or so PSI cranking at the rail, 12v at the injector but no ground pulse from PCM. Anything else to check? I'm thinking my used '01 Ram manual trans PCM has said farewell. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: '00 Dakota 5.9- no ground pulse to injectors part 2
[Re: dvw]
#2759506
04/03/20 02:30 PM
04/03/20 02:30 PM
I_bleed_MOPAR
Buford, GA
No codes. No anti-theft either. Swapped in engine, harness (and ignition switch since PO had removed it), and computer from my running, driving, but totalled '00 Durango. Dakota ran for several minutes then died. Already had the fuel pump on hand as a preventative measure since the truck had 250k on it.
Tim
Re: '00 Dakota 5.9- no ground pulse to injectors UPDATE
[Re: Jim_Lusk]
#2759735
04/04/20 09:06 AM
04/04/20 09:06 AM
I_bleed_MOPAR
Buford, GA
Local pullaparts show several on hand. Probably give them a shot.
Tim
[Re: I_bleed_MOPAR]
#2762405
04/10/20 04:32 PM
04/10/20 04:32 PM
I_bleed_MOPAR
Buford, GA
It's alive.... Went to one of the local pullaparts that showed 4 Rams, 1 Durango, and 3 or 4 Dakotas (wasn't holding my breath on a V8 Dakota though). My heart was just about down to my shoes when I found the last Ram and it had a PCM in it. Every single other one did NOT have a pcm other than an '03 Dakota QC they were just putting in line but it was a 4.7.with a manual trans. Guy at the counter said Chrysler products of all kinds were big sellers as far as PCM's went. Muffler shop here I come. Tim
[Re: I_bleed_MOPAR]
#2762414
04/10/20 04:51 PM
04/10/20 04:51 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
Weird that it would fail at that time but I've seen weirder. Glad to hear you got it going!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2762582
04/11/20 07:55 AM
04/11/20 07:55 AM
I_bleed_MOPAR
Buford, GA
28 years as a 'yota tech and never saw that before either, Jonesy. I know I'm getting old but all I can remember having to replace an ECM on a 'yota was 1 time on a Sienna van (mid-2000s?). Forget what it was doing but it still ran. Honestly don't remember if it was running bad or just setting a code/codes. I even had several lightning-struck vehicles with multiple problems but the ECM was fine (both cars struck while driving ). I know I told you in a PM but thanks ever so much for your help. Thanks to all who who offered suggestions. Tim
