i panel bond a lot
i should say weld/ bond because now we use a squeeze type welder and weld thru the glue when it's wet.
the panel overlaps are the same as welding.
grind the flanges being bonded with 36 grit to give the glue something more to grab on to.
and there is a newer glue, impact bonding adhesive that has a little more shear strength.
both glues use a special applicator to use them.
yes it's possible to mix the glue up like body filler. doing so is asking for some big problems if you do this. i would strongly recommend against trying this.
impact bond
