B Block Rebuild Kit #2759117
04/02/20 08:18 PM
04/02/20 08:18 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
Need to rebuild my 71 383 Engine. All stock except 0.030 over.
Looking for suggestions on a complete kit with Pistons, no Cam. and where to purchase.
Re: B Block Rebuild Kit [Re: Paul G] #2759181
04/02/20 11:18 PM
04/02/20 11:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Contact Bob George Racing he can get you the good parts and advice up
Gus beer
64 Plymouth Savoy
Dana 60
Re: B Block Rebuild Kit [Re: Paul G] #2759199
04/03/20 12:32 AM
04/03/20 12:32 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
whatever you get make sure the kit has the correct pistons, otherwise you will have an 7.5 to1 compression
Re: B Block Rebuild Kit [Re: CSK] #2759297
04/03/20 09:00 AM
04/03/20 09:00 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I used a sealed power kit for a 383. it had 2315 forged pistons. rings, bearings and it worked out well. the gaskets were a little limited in the kit but the hard parts worked fine.
