Re: Need some time slips
[Re: Locomotion]
#2759166
04/02/20 10:45 PM
04/02/20 10:45 PM
Posts: 3,069 Michigan
A727Tflite
Thanks - didn’t know this info existed. Now I need to see which A,B cars fit the bill - looking for Mopars only.
[Re: A727Tflite]
#2759174
04/02/20 11:06 PM
04/02/20 11:06 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You could go to D1TV or DragracerTV on YT and watch past Divisional races. Stock qualifying would be best Live timing is displayed on the screen for each run along with car info. Plus video obviously.
Stockers would be cars that aren't highly modified and have been thrashed on to go as fast as possible under the rules. Not unusual for the fast guys to lift at 1000'. D3 has a lot of Mopars if that matters.
[Re: nss guy]
#2759286
04/03/20 08:39 AM
04/03/20 08:39 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
TRANSMAN I HVE A BUNCH OF THEM IN THE CAR BUT ITS IN STORAGE RIGHT NOW WILL GET IT OUT NEXT WEEK..
JAKES AUTOMOTIVE
[Re: CMcAllister]
#2759288
04/03/20 08:42 AM
04/03/20 08:42 AM
A727Tflite
Stockers would be cars that aren't highly modified and have been thrashed on to go as fast as possible under the rules. Not unusual for the fast guys to lift at 1000'. D3 has a lot of Mopars if that matters. Thanks again. Yes, need to be Mopars as I want to use the baseline car (factored HP vs. weight).
[Re: nss guy]
#2759328
04/03/20 09:50 AM
04/03/20 09:50 AM
Posts: 4,669 Wichita
GY3
Wichita
10.24 slip 499ci auto 10.5 tires thru mufflers 3480lbs Thanks for this slip! Due to the rainy season last year and a running only 1/8th mile events end of year, I have run almost identical to every incremental on that slip save for the 10.24! I had plugged the numbers into the Wallace calculator but good to see a similar car do it in real life! It gives me a goal this season.
[Re: GY3]
#2759363
04/03/20 10:31 AM
04/03/20 10:31 AM
Posts: 9,824 MI, usa
dvw
MI, usa
No slips laying around. But after 1500 passes in my 63 Dodge. 3450lbs, 1.42-4 60 ft, 6.70@104/660 10.50@127. 10.5x29.5, 4.10 Doug
[Re: GY3]
#2759446
04/03/20 12:39 PM
04/03/20 12:39 PM
Posts: 1,442 central ohio
nss guy
central ohio
10.24 slip 499ci auto 10.5 tires thru mufflers 3480lbs Thanks for this slip! Due to the rainy season last year and a running only 1/8th mile events end of year, I have run almost identical to every incremental on that slip save for the 10.24! I had plugged the numbers into the Wallace calculator but good to see a similar car do it in real life! It gives me a goal this season. Couple more details for you to compare. 29.5x10.5x15 slicks and 4.30 gears. shift rpm 6200
[Re: A727Tflite]
#2759627
04/03/20 08:21 PM
04/03/20 08:21 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stockers would be cars that aren't highly modified and have been thrashed on to go as fast as possible under the rules. Not unusual for the fast guys to lift at 1000'. D3 has a lot of Mopars if that matters. Thanks again. Yes, need to be Mopars as I want to use the baseline car (factored HP vs. weight). Seems like a lot of those in D3 and you know they will usually have the lightweight stuff in the trans, converter figured out, gear ratios right, chassis squared away, etc. So a pretty decent example of how fast they should be going at a certain power/weight. Gonna have to be a big block or Hemi car to get into the low 10s. Can always watch Super Stock while you're there.
[Re: CMcAllister]
#2759646
04/03/20 09:11 PM
04/03/20 09:11 PM
Posts: 250 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
1977 Plymouth Volare. 2900 lbs. 904 trans, 4.86 gear. stock stroke 360'', W2 heads. 10.8:1 compression. shift at 6500 rpm
60' 1.46 330 4.225 1/8 6.585 MPH 103.86 1000 8.64
1/4 10.40 MPH 128.54
only have 6 passes on car. should run 10.20's once tuned
[Re: Locomotion]
#2759655
04/03/20 09:47 PM
04/03/20 09:47 PM
A727Tflite
Thanks. Pretty dismal, we (Chrysler) were not represented very well in the qualifying field in the upper ranks.
[Re: A727Tflite]
#2759729
04/04/20 08:37 AM
04/04/20 08:37 AM
Posts: 16,923 NC
440Jim
NC
They may not be complete timeslips, but many people listed some 1/4 mile info on "Unlawful's Fastest Car List". ---10 second Zone --- 10.004 @ 132.71, 1.393 60 foot 3300 lb. 68 Dart,dbran451 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.02 @ 132, 1.42 60', TonyS451, 71 Demon, 451 Indy SR's, street legal 3 1/2" x pipe, ultra flo mufflers, 28x10 Quicktime pros,caltracs and #3350 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.08 @ 135 1.40 60' 500cid w/Indy SRs Flat Tappet thru Mufflers on DOT's TC67CUDA 10.098 @133.35, 1.418 60� 68 RoadRunner, 528 Indy Maxx, MRMOPAR 10.10 @ 130, 1.36 60' 440RB Eddys Comp 590cam pump gas 3400#, 10sec440 10.14 @ 138.02,1.62 60 ft, 82 Rampage 2.4 turbo 16v auto.30 psi boost, Rampage16v 10.14 @136 69 Sport Satellite 3900#,KP440,346 iron heads METAL STORM 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.14 @ 129 1.29 60' 474 Low Deck Stage IV heads .613 FT cam single dominator Turbo 400 W/brakeDana 60 4.88s 3100# dry 1974 474 Duster 10.16 @ 130.3, 1.40 60�, 68 Dart 496. T748 10.16 @ 129.72,1.42 60' 69 Dart GTS 440 RB,RPM heads,.590 cam 3150# Deaks 10.18 @ 131, 1.37 60�, Demon pump gas,street tires,and muff.all steel except hood.mild 493 grncpe 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA
[Re: 440Jim]
#2759765
04/04/20 10:31 AM
04/04/20 10:31 AM
A727Tflite
Thanks 440Jim.
Final question - who has dyno results for their engine where the car is approx 3400 on the starting line, auto trans from this list.
If anyone has those dyno results and are willing to share I would appreciate seeing them. PM or post as you wish.
[Re: A727Tflite]
#2759778
04/04/20 11:05 AM
04/04/20 11:05 AM
Posts: 4,974 new jersey usa
11secdart
new jersey usa
68 Dart, 3,150 lbs. with driver, 408 s/b,R3 block, indy 360-1 heads, pump gas, 904, 539 hp, 502 tq runs 11.50 @ 114 1.51 60ft on stop, best of 10.69 @124 1.46 60ft …. With W2 head , 5.9 block , race gas 363, 904 , 549 hp, 450 tq went best of 10.40, @125 1.40 60ft
