Re: Console Wiring
[Re: gtx6970]
#2759115
04/02/20 08:17 PM
04/02/20 08:17 PM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
There is plug under the drivers side kick panel for the console wiring Not now there is not due to the car being totally apart and now going together. Looking at what I have the dome light plugs into the main harness at the kick panel there is no other plug. However I can see unplugging the dome and plugging in the console wiring as there are male and female plugs on the console harness that would allow them to all plug in.. So if that's the case where were the wires run from the kick panel area to the console. I would like to run them like the factory did.
Re: Console Wiring
[Re: NITROUSN]
#2759274
04/03/20 08:07 AM
04/03/20 08:07 AM
Posts: 601 Mass
charge70
Mass
The console wiring piggybacks into the dome lamp wiring connector and that works the console side lights.Then there should be a single orange wire running from the fuse box to work the shift indicator light.If your car didn't have a console originally,you will need to run that wire to have the shifter lamp work.The wiring runs down the inner rocker panel,at the end of the 1st foldover cover, the console wiring exits there.It then runs across the floor pan to the base of the console.they originally had clips holding the wire down you should be able to fab something or use duct tape.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Console Wiring
[Re: mccannix]
#2759354
04/03/20 10:14 AM
04/03/20 10:14 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I have a complete original 69 wire harness. If you are in need feel free to PM me. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Console Wiring
[Re: mccannix]
#2759420
04/03/20 11:44 AM
04/03/20 11:44 AM
Posts: 601 Mass
charge70
Mass
I may be wrong but would this be the correct wiring Terry,I believe that is a 68 and down harness as they had the reverse switch inside the console not on the transmission.
Re: Console Wiring
[Re: mccannix]
#2759581
04/03/20 06:32 PM
04/03/20 06:32 PM
Posts: 6,342 SE PA.
QuickBpBp
SE PA.
I may be wrong but would this be the correct wiring Don't know what that extra plug would go.. The long one on the right early b-body Clock???
Re: Console Wiring
[Re: QuickBpBp]
#2759635
04/03/20 08:38 PM
04/03/20 08:38 PM
Posts: 4,782 Ontario, Canada
mccannix
Ontario, Canada
Don't know what that extra plug would go.. The long one on the right early b-body Clock??? Early B-body console clocks had two female and one male bullet style ends. This particular harness is the 66 Charger clock wiring, clock ends shown top right
