Electric fuel pump only works when whacked..
#2758988
04/02/20 03:51 PM
04/02/20 03:51 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Hey guys & gals,
I've got an electric fuel pump failure on a friend's 1977 car, original part, so it's some 45 years old. It will start working when I tap the motor housing a number of times with the handle of a screw driver.. but it's unreliable.
Does that type of failure tell me anything useful? Like is that classic symptoms for "worn brushes" or something? ..and then I can try a rebuild?
The electric motor is in a metal "can" that's crimped shut, so opening it may be one-way trip to the trash bin. I want to know as much as I can before deciding to open it or not. OEM replacement is not available, but I've installed a temporary "loaner" to keep the car running.
Thank you, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Electric fuel pump only works when whacked..
[Re: stumpy]
#2759746
04/04/20 09:29 AM
04/04/20 09:29 AM
67SATisfaction
Albany, NY
Thanks guys, That gives me some confidence to proceed. Yeah, there are lots of aftermarket options. I'm looking into what the OEM flow rate and PSI are. The spare pump I cobbed in there is really loud, so that's why I'm not done yet. Cheers, - Art
