Re: No Start - Mallory Hyfire 6al
[Re: dd340]
#2758500
04/01/20 05:20 PM
04/01/20 05:20 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I'd hook a wire to the Neg of the coil and with the coil lead set off of the block, turn the ignition on and tap that wire to the block to test the coil.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: dd340]
#2759130
04/02/20 08:58 PM
04/02/20 08:58 PM
Posts: 5,893 Florida
Locomotion
Just a few ideas.....Do you have another distributor and/or coil (check compatibility) you could adapt & try? I recall hearing that the Uni-lite distributors can go bad, but don't recall the symptoms. (Dirty window?) Gotta ask - firing order correct or timing moved? I've run a Malloryr 6AL with one of their magnetic pick-up distributors for 15+ years with no issues.
EDIT - I did have one issue: One of the pins in the distributor lead pushed back in the plug and had an intermittent connection.
[Re: dd340]
#2760430
04/05/20 04:17 PM
04/05/20 04:17 PM
Posts: 4,457 Washington
madscientist
Washington
Turns out the Mallory box was bad. I scrounged up a spare and it had at least 10x the spark. I’m not sure how it can go bad but still have a small spark but that’s exactly what happened. What’s the part number of the box? Also, if you PM me I’ll give you the email address fo the guy at Mallory who was the head engineer on most of those boxes and he fixes them pretty cheap. If it’s the part number I like and you don’t want it I’d be interested in buying it.
[Re: madscientist]
#2760481
04/05/20 06:19 PM
04/05/20 06:19 PM
Dave_J
Auburn WA
I will be running my old Mallory VI-AL (Not 6-AL) on my LRT build. It works good when wired right. But a loose ground almost made me toss it years ago.
