Will the motor run dry? #275836
04/03/09 10:55 AM
04/03/09 10:55 AM
Indiana
rapid67rt Offline OP
Indiana
Just put a 493 stroker in my 71 dart. Had to go with a 5qt pan due to the idler arm. Wondering if the motor would run dry????? Have 1/2 inch pickup,Windage tray. Can't find a pan with the correct clearance?
Re: Will the motor run dry? [Re: rapid67rt] #275837
04/03/09 10:56 AM
04/03/09 10:56 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I doubt if it will ever run dry.
Re: Will the motor run dry? [Re: stumpy] #275838
04/03/09 11:09 AM
04/03/09 11:09 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
what oil pump, what heads, what type of rpm does it see?
Re: Will the motor run dry? [Re: moper] #275839
04/03/09 11:38 AM
04/03/09 11:38 AM
Indiana
Indiana
high volume oil pump,452 heads. rpm would be good to 7000 with the cam being used.
Re: Will the motor run dry? [Re: rapid67rt] #275840
04/03/09 12:20 PM
04/03/09 12:20 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Nope, not enough IMO. You can overfill it by 1 qt, and run the longer filter. But IMO, you need at least 7 qts, which would be an overfilled Hemi pan. 7K and a HV pump needs a lot of oil volume.
Re: Will the motor run dry? [Re: moper] #275841
04/03/09 12:59 PM
04/03/09 12:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
High volume pumps won't suck a pan dry. That's an old wives tale. This has been didcussed over and over again.
Re: Will the motor run dry? [Re: stumpy] #275842
04/03/09 01:03 PM
04/03/09 01:03 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
at 7K, with only a 5qt sump, they very well might. That's why I asked.
Re: Will the motor run dry? [Re: moper] #275843
04/03/09 01:37 PM
04/03/09 01:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Unless the oil returns are all plugged the oil will go back as fast as it gets sucked out. The oil still has to go through the same very limited escape routes between the bearings and a high volume pump doesn't make those any bigger.
Re: Will the motor run dry? [Re: stumpy] #275844
04/03/09 02:24 PM
04/03/09 02:24 PM
Az
Crizila Offline
Crizila  Offline
Az
That's a big 10-4! - not to mention why would you want to run a 493 to 7K.
Fastest 300
Re: Will the motor run dry? [Re: Crizila] #275845
04/03/09 06:07 PM
04/03/09 06:07 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I agree. And it will get backed up in the valley and around the crank at that rpm. Not to mention G forces pusing it up the back of the pan. We agree on the idea. I suppose I'm a little more cautious about applying it to every situation...lol.
Re: Will the motor run dry? [Re: rapid67rt] #275846
04/03/09 06:09 PM
04/03/09 06:09 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
There has to be a pan that will work.
SS cars, etc run big blocks in those cars.
I want my fair share
Re: Will the motor run dry? [Re: SomeCarGuy] #275847
04/03/09 10:38 PM
04/03/09 10:38 PM
Indiana
Indiana
Ok,thanks for the info. I wouldnt run it at 7k, just said it was good to that rpm. I'm sure other people have had this problem with the pan being hit by the idler. Havent found a pan that would work.
Re: Will the motor run dry? [Re: rapid67rt] #275848
04/03/09 10:43 PM
04/03/09 10:43 PM
Theres a lot more to "big engines" and "small oil" than the size of the pump.
First, with a huge be stroker motor, you've got LOTS more windage, and less room to deal with it. That causes foaming problems. One reason to use a deep pan is NOT to get more oil, but to get the oil sump FURTHER from the crank
Any engine that you "tend" to run harder (more RPM, more accelleration) is going to cause oil starvation and foaming problems
I say, figure out how to get a bigger pan in there. You're not the first guy to put a "big mota" in a Mopar
Re: Will the motor run dry? #275849
04/03/09 11:37 PM
04/03/09 11:37 PM
I'd set the pickup ~1/8 off the bottom rather than flat like commonly recommended. High rpm/hi vol pump, I think that could end up causing starvation by being a restriction.
Re: Will the motor run dry? [Re: rapid67rt] #275850
04/04/09 02:17 AM
04/04/09 02:17 AM
I use the 1970-71 stock Hemi-440-6pak oil pan in my Duster with a stroker BB,my motor is slid back one inch from the stock location based on the trans mount. I did have to trim the backside of the K member some to get the pan to clear, I used the stock 440-6pak 3/8 pick up also The motor pulls really hard to 7300+rpm and I've never had a oiling related problem yet in three + years of hard street and strip driving. I use a stock Mopar windage tray and I built the crankshaft scraper for the motor I also had the #4 cam journal grooved so the rockers would oil full time still no oiling return issues that I'm aware of, the motor has been apart several times changing parts and inspecting for the next years use there are a number of oil pans that will work in your chassis but most of the aftermarket ones are a deep sump like the Moroso and Milidons, which for a street car I don't like or use
Re: Will the motor run dry? [Re: Cab_Burge] #275851
04/04/09 03:24 AM
04/04/09 03:24 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
I suck the pan dry in my Demon's 340 (TRW HV pump, stock pan, baffled and with a windage tray) if I don't run it a quart high. Only under heavy acceleration.
Re: Will the motor run dry? [Re: Hotwheelsjr] #275852
04/04/09 10:25 AM
04/04/09 10:25 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
And how would you know that?
Re: Will the motor run dry? [Re: I go fast] #275853
04/04/09 11:55 AM
04/04/09 11:55 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i imagine he watches the oil pressure gauge
Re: Will the motor run dry? [Re: dirtybee] #275854
04/04/09 12:42 PM
04/04/09 12:42 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Yep, that would do it.
Re: Will the motor run dry? [Re: dirtybee] #275855
04/04/09 12:43 PM
04/04/09 12:43 PM
California
mickm Offline
mickm  Offline
California
yeah, with his wallet!
