Re: Will the motor run dry? [Re: dirtybee] #275856
04/05/09 09:34 PM
04/05/09 09:34 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
i imagine he watches the oil pressure gauge
Had to remove a pan and weld in some baffles/trap door to solve this problem. Stock pan allows too much oil out of the middle portion of a stock pan.
Re: Will the motor run dry? [Re: I go fast] #275857
04/06/09 12:58 AM
04/06/09 12:58 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I had my 340 suck the pan dry at 7000. How do I know, low oil pressure light and a spun rod bearing. High volume oil pump and a stock capacity pan and 7000 rpm in each gear including drive dont work well.
Yes I spanked the Mustang through the mile mark but at what cost. So I built a stroker 422ci best rod bearing I ever spun.
Re: Will the motor run dry? [Re: dirtybee] #275858
04/08/09 02:56 AM
04/08/09 02:56 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
How else?
When I see my oil pressure drop under acceleration instead of climb rapidly, I can only assume I am sucking air.
