4wheel drive and supercharging? #2758240
03/31/20 11:50 PM
03/31/20 11:50 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Will the standard 4 wheel setup in a 2014 Grand Cherokee Overland 5.7 hemi handle the 150hp boost of a procharger? I believe it uses the Quadra-Drive II. Thanks
Re: 4wheel drive and supercharging? [Re: stumpy] #2759583
04/03/20 06:38 PM
04/03/20 06:38 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i would guess not----- the chrysler 300 ran an all wheel drive behind the 5.7-------when the hemi grew larger---the all wheel was history---RWD only...you might check to see which transfer case is used under the new HOT cherokees though...
Re: 4wheel drive and supercharging? [Re: stumpy] #2759590
04/03/20 06:45 PM
04/03/20 06:45 PM
Guitar Jones Offline
The cars used a different transfer case than the trucks. Try checking the tag on the transfer case for the model # then google the torque rating.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 4wheel drive and supercharging? [Re: Guitar Jones] #2764143
04/15/20 09:28 AM
04/15/20 09:28 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I imagine you ill be OK, lots of people pushing stock stuff way past its limits. Will it shorten the life of it? Probably. Will it explode the first time you hammer it? No(I mean probably not, but I guess it could lol).
68 Barracuda Formula S 340
