Its one of those what fluid to use for power steering posts #2756569
03/27/20 06:02 PM
03/27/20 06:02 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I don't have an owner's manual for the 91 Ramcharger, I'm looking for the recommended fluid to use in the power steering.
My 92 Dakota says ATF, but it is rack and pinion.
I've used ATF in other 1st gen and older Mopars, but this is going to be a new steering box, pump, and lines, so I figured since I'm starting from scratch I may as well use what it called for.
It's primarily a winter and crappy weather beater, so the best flowing fluid for cold weather is best option.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Its one of those what fluid to use for power steering posts [Re: hp383] #2756573
03/27/20 06:09 PM
03/27/20 06:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive always used nothing but mopar brand ATF in any mopar system
Re: Its one of those what fluid to use for power steering posts [Re: gtx6970] #2756577
03/27/20 06:13 PM
03/27/20 06:13 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
It would help if we knew what year, make, model, and engine size??
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Its one of those what fluid to use for power steering posts [Re: Dartsport540] #2756578
03/27/20 06:17 PM
03/27/20 06:17 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Updated, 91 Ramcharger.
Engine is 318 if thats of importance for some reason.
Re: Its one of those what fluid to use for power steering posts [Re: hp383] #2756580
03/27/20 06:22 PM
03/27/20 06:22 PM
Ringtown, Pa.
Ringtown, Pa.
Identifix/ Direct hit, which uses mopars Factory info. Lists Mopar P/N 04883077 (MS-5931) Power steering fluid.
Re: Its one of those what fluid to use for power steering posts [Re: Dartsport540] #2756583
03/27/20 06:26 PM
03/27/20 06:26 PM
Ringtown, Pa.
Ringtown, Pa.
I am not at my business right now. But I would have to check on my Power Steering fluid bottle and my Synthetic ATF fluid paper work. They both have a list of the specs or fluid specs that they cover. I could check tomorrow morning, and post back here.
Re: Its one of those what fluid to use for power steering posts [Re: Dartsport540] #2756586
03/27/20 06:45 PM
03/27/20 06:45 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
That would be great. The truck goes under the knife early next week.
Re: Its one of those what fluid to use for power steering posts [Re: hp383] #2756649
03/27/20 09:51 PM
03/27/20 09:51 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Re: Its one of those what fluid to use for power steering posts [Re: Magnum] #2756666
03/27/20 10:19 PM
03/27/20 10:19 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
other than one specific year (forget exactly when) that Mopar said to use one or the other/ but specifically said NOT to use the other fluid between the 2, it was much newer than you are talking.... but the next year, they flip flopped back the other way. otherwise I have seen them say to use one or the other, with the other as an "acceptable substitute".
I would say to use which ever you have on hand and keep it that way..... not inner mixing the 2, would be the more important factor. If you start with ATF, keep it ATF as long as you continue to own it.
same thing can be said about "power steering fluid" if you wanna swap fluids, drain and flush the old stuff out, and run 100% of one or the other. all the time.
Re: Its one of those what fluid to use for power steering posts [Re: volaredon] #2756770
03/28/20 09:48 AM
03/28/20 09:48 AM
Ringtown, Pa.
Ringtown, Pa.
Suppose to be power steering fluid that meets Mopar SPEC # 5931 .. Going to have to look on the back of some power steering fluids available in your area...
Re: Its one of those what fluid to use for power steering posts [Re: Dartsport540] #2756789
03/28/20 10:37 AM
03/28/20 10:37 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Mopar had Power Steering Fluid for years
But when the ATF improved to ATF +4 most of the old parts numbers for PS fluid superseded to that
So your 91 Ramcharger would work fine with either
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Its one of those what fluid to use for power steering posts [Re: moparts] #2756794
03/28/20 10:46 AM
03/28/20 10:46 AM
5thAve Offline
5thAve  Offline
Use actual power steering fluid like it was originally intented for.
Even GM stuff that was quick to change to ATF in the 80s, it seems they used that in rack and pinion and power steering fluid in the older style pumps and boxes.
Re: Its one of those what fluid to use for power steering posts [Re: 5thAve] #2758218
03/31/20 10:45 PM
03/31/20 10:45 PM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
Generally, ATF+4 and power steering fluid should interchange in modern cars.
Power steering fluid has chemistry to reduce noise, so in general it is preferred.
With older models, stick with PS fluid only, to reduce noise.
I worked at Mopar for a few years, learned this there.
Mark
Re: Its one of those what fluid to use for power steering posts [Re: michiganhotrod1] #2758235
03/31/20 11:28 PM
03/31/20 11:28 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
x 99 .... R E A L power steering fluid! .... unless you are in a climate that is REALLY cold !
Re: Its one of those what fluid to use for power steering posts [Re: dOrk !] #2758294
04/01/20 08:21 AM
04/01/20 08:21 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Thanks all.
I got the steering box, hoses, lines, etc. changed yesterday, and the system now has fresh power steering fluid.
Re: Its one of those what fluid to use for power steering posts [Re: hp383] #2758295
04/01/20 08:27 AM
04/01/20 08:27 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I have always used https://www.amazon.com/CRC-SL2641-Power-Steering-Fluid/dp/B000M8Q1ZS
It was fine in my old stuff. I`m not sure about a 91 vehicle though.
Re: Its one of those what fluid to use for power steering posts [Re: mopars4ever] #2758304
04/01/20 09:04 AM
04/01/20 09:04 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Mopars with Saginaw pumps and 72-93 trucks which have Saginaw boxes the GM cold weather P/S fluid works great. Gets rid of that whine they get with regular p/s fluid.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
