door hinge pins #2757637
03/30/20 03:20 PM
03/30/20 03:20 PM
md
mopars4ever Offline OP
md
Will Resto Ricks door hinge rebuild kit work on a 77 F body? I need to rebuild the driver side lower hinge. I guess I only really need the pins. It is worn but not bad but I want to rebuild it before paint. I have a NOS upper one. It is my understanding to not use bushings in the lower and to use oversize pins.
Re: door hinge pins [Re: mopars4ever] #2757709
03/30/20 07:05 PM
03/30/20 07:05 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Or weld the up holes in the lower, redrill with a new pin.
Re: door hinge pins [Re: 4406bbl] #2758061
03/31/20 04:19 PM
03/31/20 04:19 PM
md
md
I think I am going to weld it up. It isn`t too bad. Thanks
