1st Gen. Hemi plug wires? #2757913
03/31/20 09:57 AM
03/31/20 09:57 AM
Halifax, VA.
moparjack44 Offline OP
Halifax, VA.
MoPar Mall has direct fit, pre cut 392 Hemi plug wires. It says the core is wire. Two (2) questions. Will the core wires interfere with AM/FM/Sirrus radio? I have Hot Heads valve covers (taller than stock), will the original pre cut wires fit?
Jack
K.I.S.S.
Re: 1st Hemi plug wires [Re: moparjack44] #2758001
03/31/20 01:19 PM
03/31/20 01:19 PM
Halifax, VA.
Halifax, VA.
Jack
Dang. Title should read "1st Gen Hemi plug wires". Is this something a moderator can correct. Sorry.
Jack
K.I.S.S.
Re: 1st Hemi plug wires [Re: moparjack44] #2758020
03/31/20 02:35 PM
03/31/20 02:35 PM
You can do it when you select edit function, put the cursor on the top line and make it read the way you want it now up scope
Re: 1st Hemi plug wires [Re: Cab_Burge] #2758022
03/31/20 02:39 PM
03/31/20 02:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Solid-core wires will interfere with a lot of stuff - been there, way back - unless jacketed.
Best to contact them and get specifics, or look for "will not cause RF interference".
Re: 1st Hemi plug wires [Re: moparjack44] #2758266
04/01/20 02:17 AM
04/01/20 02:17 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi today you want spiral core wire ! not solid core wire !
also solid core can not be used with msd !
Re: 1st Hemi plug wires [Re: calrobb2000] #2759365
04/03/20 10:32 AM
04/03/20 10:32 AM
Halifax, VA.
Halifax, VA.
Bummer down. I do have MSD ignition. Thanks.
K.I.S.S.
Re: 1st Hemi plug wires [Re: moparjack44] #2759491
04/03/20 02:03 PM
04/03/20 02:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The wires will fit with taller valve covers because the rubber boot is separate. In fact, they may not even come with the boot. If it were me I'd just bey 'em from Hot Heads.
Re: 1st Hemi plug wires [Re: Stanton] #2759530
04/03/20 03:37 PM
04/03/20 03:37 PM
Halifax, VA.
Halifax, VA.
Yay, that's what I have always done before. Just thought pre cut would look better, but looks like not a good idea?
K.I.S.S.
