Re: New spring perches, larger hole size
[Re: Suregrip391]
#2757732
03/30/20 07:51 PM
03/30/20 07:51 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I just went through this on my Dart. I like them to be centered. I cut a couple spacers out of 3/8 pipe, I think it was. Got lucky as it fit great over the pin and in the hole. They centered the perches up on the springs.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Suregrip391]
#2757735
03/30/20 08:00 PM
03/30/20 08:00 PM
Posts: 13,572 md
mopars4ever
md
[Re: mopars4ever]
#2757755
03/30/20 08:24 PM
03/30/20 08:24 PM
Posts: 20,745 A collage of whims
topside
A collage of whims
I'd want to drop the rearend on there, bolt it up, measure the wheelbase. Get that right & equal both sides. If the holes are concentric, I'd want to sleeve the locating pins for race use so the axle can't re-locate itself. If not concentric, double-check measurements, break out a die grinder & bit, make them concentric, and sleeve 'em. For street use, sleeving is probably not necessary, depends on power/shock loads/grip.
[Re: hemi-itis]
#2757836
03/31/20 12:29 AM
03/31/20 12:29 AM
moparmarks
Seems some of the replacement perches have a larger hole. I have inboard springs with new perches. There was a lot of slop. I wanted it all centered up so it didn't go down the road sideways like an old Chevy truck.
[Re: mopars4ever]
#2757839
03/31/20 12:31 AM
03/31/20 12:31 AM
moparmarks
[Re: moparmarks]
#2757854
03/31/20 01:30 AM
03/31/20 01:30 AM
Posts: 43,115 Bend,OR USA
Cab_Burge
[Re: moparmarks]
#2757969
03/31/20 12:15 PM
03/31/20 12:15 PM
Posts: 421 montana
BANDIT
montana
Yup, that’s what I do on all the street car rears I narrow, you can buy the tubing by the foot and just tack weld a 3/4 “ on inside of perch. Moroso or Competition Engineering make em with 1/2” hole, but they used to be spendy. That is by far the quickest and most cost effective way to do it. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BDW]
#2758091
03/31/20 05:40 PM
03/31/20 05:40 PM
Posts: 8,129 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
[Re: UCUDANT]
#2758296
04/01/20 08:28 AM
04/01/20 08:28 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I stopped buying the Mopar perches and switched to the Moroso for that reason. On the several spring, and axle swaps I have done I have never once had the Mopar perch sized centering pin. It hasn't mattered if the springs were stock 30yr old or brand new aftermarket, the locating pin has always been the smaller diameter.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#2758350
04/01/20 11:22 AM
04/01/20 11:22 AM
moparmarks
Those Mopar perches look like they are for the 73-up B Isolation setup.
[Re: 1969ronnie]
#2762830
04/11/20 07:46 PM
04/11/20 07:46 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
The bigger hole perches from Mopar are from their truck parts bin, resold as Performance Parts.
I love the cut pipe spacer idea. Why build a car and allow the rear housing not to be accurately located? No wonder some of the Mopars out there are crapboxes.
As much precision that can be controlled by me, gets the go ahead.
