Mancini has some small block unmachined forgings for cheap.
220.00
Since I am in the middle of exploring options for a stroker kit , I am wondering if this makes any sense.
I know where there is a set of Carillo 6.125 rods for cheap , and they are small journal Chevrolet size on the big end.
So would it be financially prudent to snag one of these crank shafts , have it offset ground and sized for a 4 " stroke or so , and cyro or heat treated ?
I am guessing that there is very close to enough material to pull this off , even though they say 3.79 stroke , since that is with MoPar sized journals.
Obviously , I'm trying to stick with shelf pistons.
I would be into pistons and rods for around a grand , and have a high end forged stroker rotating assembly.
But I can pick up a decent forged kit for just north of two G's.
Since there is some time before anything can be done due to the ongoing craziness , I have the luxury of entertaining silly ideas.
https://www.manciniracing.com/dealpart143.html
