Got a new one. Its weird.....
#2757569
03/30/20 12:30 PM
03/30/20 12:30 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
Got this one on Saturday. 64 d100 former California forestry truck. Poly motor, dash shifted 727 and dana 60. Also has 8 lug wheels, heavy duty suspension and a factory spot light. I am digging this one. Gonna be fun.
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
Re: Got a new one. Its weird.....
[Re: moparmarks]
#2757766
03/30/20 08:38 PM
03/30/20 08:38 PM
hosehead
Grove, OK
Thanks guys! I'm having a blast tearing it apart. Needs front floor pans but is otherwise solid. I hope to be cruising around this summer.
[Re: hosehead]
#2757812
03/30/20 10:24 PM
03/30/20 10:24 PM
Posts: 2,042 colorado
savoy64
colorado
dodge delivered short wheel base 3/4 ton trucks to the government in the 60,s there is even a forum for them-------probably the first rock crawlers....this is the first 2WD one i have seen....
[Re: savoy64]
#2757832
03/31/20 12:12 AM
03/31/20 12:12 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Phone and power companies got D100 2wd too. They ordered them with D200 axles so easy interchange of on shelf parts. But I had a OD Green US Army Maintenance bin 67 D200 with a \6 and 4 speed. It had 17's on it. Its Dana had 4:36:1 gears. Same spotlight too. Had never been off Ft Lewis from day of delivery. When I retired in 1994 it had 32,000 miles on it. From the garage to the coffee shop to the job, to lunch, back to job and back to garage.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: savoy64]
#2757845
03/31/20 12:46 AM
03/31/20 12:46 AM
hosehead
Grove, OK
dodge delivered short wheel base 3/4 ton trucks to the government in the 60,s there is even a forum for them-------probably the first rock crawlers....this is the first 2WD one i have seen.... What was the name of the forum? And thanks for all the info guys. It seems ive stumbled upon a unique little truck here. I'm pretty excited to get it going.
[Re: hosehead]
#2757888
03/31/20 08:31 AM
03/31/20 08:31 AM
Posts: 2,683 Des Moines IA
Soopernaut
Des Moines IA
dodge delivered short wheel base 3/4 ton trucks to the government in the 60,s there is even a forum for them-------probably the first rock crawlers....this is the first 2WD one i have seen.... What was the name of the forum? Sweptline.org There is a lot on that SERT sticker. The D100s usually came with 5 lug axles, but this appears to be a special order and not common. The 61-68 W100s all came with 8 lug axles and a short bed.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#2757922
03/31/20 10:31 AM
03/31/20 10:31 AM
hosehead
Grove, OK
dodge delivered short wheel base 3/4 ton trucks to the government in the 60,s there is even a forum for them-------probably the first rock crawlers....this is the first 2WD one i have seen.... What was the name of the forum? Sweptline.org There is a lot on that SERT sticker. The D100s usually came with 5 lug axles, but this appears to be a special order and not common. The 61-68 W100s all came with 8 lug axles and a short bed. I'm familiar with swept line.org. I thought he meant there was a forum for the 3/4 ton government trucks. Oh well, I'm registering at sweptline.org to learn a little more about this thing. Thanks guys.
[Re: savoy64]
#2757938
03/31/20 11:21 AM
03/31/20 11:21 AM
hosehead
Grove, OK
years back i chatted up a cemetery worker that had a tan sweptside and i thought it had 19,s he said it was BLM surplus and everyone wanted to buy it---he mentioned they even had a club----here is my interpretation----bob Oh man, that is cool. Quite similar to mine. I like it!
[Re: hosehead]
#2757954
03/31/20 11:47 AM
03/31/20 11:47 AM
savoy64
colorado
thanks---this truck has been to oklahoma----towed a 2000 mexican ramcharger home--got comments at every stop--thought a texas ranger was going to drive it for a minute....bob--this truck has a 92 cummins 5 speed getrag--205--d61 and d71.....and is an air force truck.....
[Re: savoy64]
#2758051
03/31/20 03:46 PM
03/31/20 03:46 PM
hosehead
Grove, OK
And I just ran the vin. Its an early 65.
[Re: hosehead]
#2758114
03/31/20 06:50 PM
03/31/20 06:50 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
And I just ran the vin. Its an early 65. Now Cory you need some bib overalls
Abe Lincoln
[Re: dart4forte]
#2758178
03/31/20 09:38 PM
03/31/20 09:38 PM
Posts: 614 Id
mopeman
Id
Sweet truck, I don't think I could resist not buying one if given the chance!!!
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
[Re: mopeman]
#2758216
03/31/20 10:41 PM
03/31/20 10:41 PM
hosehead
Grove, OK
found this freeloader in the oil pan today.....
[Re: hosehead]
#2758288
04/01/20 07:43 AM
04/01/20 07:43 AM
Soopernaut
Des Moines IA
And I just ran the vin. Its an early 65. When you said it was dash shifted I wondered if it was a 65. The 61-64 autos were technically dash shifted too, but it was a push button shifter to the left of the steering wheel. The early 65s switched to the lever on the dash to the right of the steering wheel.
[Re: basketcase]
#2758299
04/01/20 08:44 AM
04/01/20 08:44 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Does yours by chance have extra steel welded onto the frame rails? I had a very similar 64 or 65, 25ish years ago, and it had 4.56 gears, poly 318, dash shifter, 8 lug wheels, and it had a short flatbed installed when I got it so not sure the original bed style.
But the frame rails had additional steel welded to the the underside to make the overall height of the frame taller/thicker. IIRC it was like a 3/4" or so flat strap the full length of each frame rail. Supposedly this was because it was a Forestry truck for the conditions in which it was intended to be used.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#2758315
04/01/20 09:47 AM
04/01/20 09:47 AM
hosehead
Grove, OK
But the frame rails had additional steel welded to the the underside to make the overall height of the frame taller/thicker. IIRC it was like a 3/4" or so flat strap the full length of each frame rail. Supposedly this was because it was a Forestry truck for the conditions in which it was intended to be used. I will check today!
[Re: Soopernaut]
#2758316
04/01/20 09:48 AM
04/01/20 09:48 AM
hosehead
Grove, OK
And I just ran the vin. Its an early 65. When you said it was dash shifted I wondered if it was a 65. The 61-64 autos were technically dash shifted too, but it was a push button shifter to the left of the steering wheel. The early 65s switched to the lever on the dash to the right of the steering wheel. Yes, that is the case. bear with me, as I am still learning these 60's trucks. I guess the shifter is not unique in this case..
[Re: hosehead]
#2758327
04/01/20 10:24 AM
04/01/20 10:24 AM
dart4forte
Mesa, Arizona
found this freeloader in the oil pan today..... What the heck is that?
Abe Lincoln
[Re: dart4forte]
#2758610
04/01/20 08:45 PM
04/01/20 08:45 PM
hosehead
Grove, OK
found this freeloader in the oil pan today..... What the heck is that? a marinated lizard. lol. sitting on the pickup. he's large.
[Re: hosehead]
#2759071
04/02/20 07:03 PM
04/02/20 07:03 PM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
That is a really cool truck. Congrats!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2759134
04/02/20 09:04 PM
04/02/20 09:04 PM
hosehead
Grove, OK
That is a really cool truck. Congrats! Thank you! I am really digging it.
