Re: Got a new one. Its weird.....
[Re: hosehead]
#2758288
04/01/20 07:43 AM
04/01/20 07:43 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
And I just ran the vin. Its an early 65. When you said it was dash shifted I wondered if it was a 65. The 61-64 autos were technically dash shifted too, but it was a push button shifter to the left of the steering wheel. The early 65s switched to the lever on the dash to the right of the steering wheel.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: basketcase]
#2758299
04/01/20 08:44 AM
04/01/20 08:44 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Does yours by chance have extra steel welded onto the frame rails? I had a very similar 64 or 65, 25ish years ago, and it had 4.56 gears, poly 318, dash shifter, 8 lug wheels, and it had a short flatbed installed when I got it so not sure the original bed style.
But the frame rails had additional steel welded to the the underside to make the overall height of the frame taller/thicker. IIRC it was like a 3/4" or so flat strap the full length of each frame rail. Supposedly this was because it was a Forestry truck for the conditions in which it was intended to be used.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#2758315
04/01/20 09:47 AM
04/01/20 09:47 AM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
But the frame rails had additional steel welded to the the underside to make the overall height of the frame taller/thicker. IIRC it was like a 3/4" or so flat strap the full length of each frame rail. Supposedly this was because it was a Forestry truck for the conditions in which it was intended to be used. I will check today!
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
[Re: Soopernaut]
#2758316
04/01/20 09:48 AM
04/01/20 09:48 AM
hosehead
Grove, OK
And I just ran the vin. Its an early 65. When you said it was dash shifted I wondered if it was a 65. The 61-64 autos were technically dash shifted too, but it was a push button shifter to the left of the steering wheel. The early 65s switched to the lever on the dash to the right of the steering wheel. Yes, that is the case. bear with me, as I am still learning these 60's trucks. I guess the shifter is not unique in this case..
[Re: hosehead]
#2758327
04/01/20 10:24 AM
04/01/20 10:24 AM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
found this freeloader in the oil pan today..... What the heck is that?
Abe Lincoln
[Re: dart4forte]
#2758610
04/01/20 08:45 PM
04/01/20 08:45 PM
hosehead
Grove, OK
found this freeloader in the oil pan today..... What the heck is that? a marinated lizard. lol. sitting on the pickup. he's large.
[Re: hosehead]
#2759071
04/02/20 07:03 PM
04/02/20 07:03 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
That is a really cool truck. Congrats!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2759134
04/02/20 09:04 PM
04/02/20 09:04 PM
hosehead
Grove, OK
That is a really cool truck. Congrats! Thank you! I am really digging it.
