Platinum plugs replacing
#2757416
03/29/20 09:55 PM
03/29/20 09:55 PM
Posts: 22,695 Bitopia
jcc
Bitopia
What visual clues do you look for to decide the right time to replace platinum plugs?
Re: Platinum plugs replacing
[Re: jcc]
#2757438
03/29/20 11:11 PM
03/29/20 11:11 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
When you can see noticeable wear on the ground strap and the center electrode as well as damage to the center porcelain insulator Or when the motor starts missing due to bad plugs or wires
[Re: jcc]
#2757444
03/29/20 11:31 PM
03/29/20 11:31 PM
Posts: 4,848 Memphis
HemiRick
Memphis
If they're Bosch platinums and its not a European car, IMMEDIATELY. Otherwise the above is good.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2757448
03/29/20 11:40 PM
03/29/20 11:40 PM
Posts: 10,550 Rittman Ohio
fourgearsavoy
Rittman Ohio
If they're Bosch platinums and its not a European car, IMMEDIATELY. Otherwise the above is good. Exactly They work OK in German cars but for anything else go NGK or Denso Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2757487
03/30/20 07:30 AM
03/30/20 07:30 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Another for trashing them if Bosch.Cant say how many sets I replaced at the shop because they were junk.Only ever saw 1 car that ran decent with thm .Even the super pricey ones were terrible.IIRC it seems that Bosch gave incentives for parts stores to push them.Rocky
Chrysler Firepower
[Re: Cab_Burge]
#2757619
03/30/20 02:44 PM
03/30/20 02:44 PM
jcc
Bitopia
When you can see noticeable wear on the ground strap and the center electrode as well as damage to the center porcelain insulator Or when the motor starts missing due to bad plugs or wires That seems reasonable. Hard to visualize wear on the center electrode, because they are so small/odd shape to begin with and don't exactly recall, and the "little" erosion I do see, seems like a regap would suffice? The one's I'm looking at are NGK, truck runs fine, coil on plug 90K on Plugs, 500K on truck. I was going Autolite Plat, because they were so cheap?
[Re: second 70]
#2757958
03/31/20 12:01 PM
03/31/20 12:01 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I changed the AC plugs on my 2004 Silverado last year at 100,000 miles and they looked new. Have people that have no problem putting over 200,000 on them. I put Iridium in this 5 yrs ago,over 100 K miles and they look like the day I put them in.
[Re: second 70]
#2757959
03/31/20 12:03 PM
03/31/20 12:03 PM
Posts: 18,153 Mass
DAYCLONA
Mass
I'm always amazed at these " Bosch Platinum plug threads" and the "anti-Bosch" bashers, I usually run nothing but Bosch Platinum/iridium, I have them in everything from 318's, 340 6 pack, 440, 440 6 pack even my V10 with ZERO issues, plenty of miles/years of usage.... I don't see any of the supposed issues that the same posters have that always condemn these plugs?....I actual dislike AC, Champion plugs (pure crap) NGK is a 2nd choice if Bosch are not in stock or available, as far as the OP's question of replacing Bosch Platinums? I've never experienced a bad Bosch plug(s) over the decades, I'll generally change them out around 75-90K or 3-4 yrs on a DD just for the hell of it...
Mike
[Re: AARCONV]
#2758331
04/01/20 10:32 AM
04/01/20 10:32 AM
Posts: 1,695 central il.
second 70
central il.
if you are taking the time to remove them to check, then just replace them..don't look back..lol Of course I replaced them after I took them out. I just stated it wasn't necessary, didn't run any better, and wouldn't worry about waiting for another 200,000 to do it the next time.
[Re: second 70]
#2758401
04/01/20 01:09 PM
04/01/20 01:09 PM
jcc
Bitopia
As OP, I took out the first plug, checked the gap, visually couldn't see why it needed replacing, re installed it, might return the 4 Autolights, which were cheap, and new, and don't look as nice as the original NGK's.
[Re: jcc]
#2758473
04/01/20 04:28 PM
04/01/20 04:28 PM
therocks
Niles , Ohio
Dayclona if you have good luck with Bosch go play the lottery.Total junk as far as Im concerned. 30 years as a tech and only saw 1 car they ran good in.My kid aslo put a set in the 61 Polara he had because they didnt have any others.Car ran terrible hard to start etc.I puled them and use Autolites.Like a new car.Like I said i replaced tons at work in cars that ran like total crap.Could not have been all the cars when one denominator was the plugs.Rocky
Chrysler Firepower
[Re: therocks]
#2758564
04/01/20 06:59 PM
04/01/20 06:59 PM
HemiRick
Memphis
Another over 30 yr exp auto tech, and I agree Bosch platinums are a way to make most cars run like crap. BTW I ALWAYS use OEM plugs in stock engines......brand and heat range.
[Re: DAYCLONA]
#2761053
04/07/20 10:49 AM
04/07/20 10:49 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Mike My experience has not been as vast as yours, but I have used them several places, and never had an issue. In my old carb'd 2.2L engines, they were the trick to curing a random miss when idling in open loop.
