Re: Old TRW forged 340 piston #2332P
[Re: Moparnut426]
#746025
08/09/11 06:58 PM
08/09/11 06:58 PM
Posts: 2,091 Delray beach, Florida
Performance Only
if thesmall dome just cancels out the cc's of the valve reliefs, you should be at 10.6-1 c/r with the right cam and timing curve you should be able to run on pump gas without any problem.
machine shop owner and engine builder
[Re: Performance Only]
#746031
08/10/11 04:12 AM
08/10/11 04:12 AM
Posts: 2,128 sweden
sshemi
sweden
a better idea would be to send the heads back and get the "closed" chamber modell and then mill the pistons to get 0 deck height. That way if you want to build anything else in the future it will be easy to get pistons witch is not the case with the your heads.
he already has the closed chamber heads, not the open chamber.
Then the pistons wont fit. They go above the deck.
[Re: sshemi]
#2756918
03/28/20 03:38 PM
03/28/20 03:38 PM
Posts: 42 British Columbia Canada
Chargervic
Re: Sealed Power 2332P and TRW L2316F pistons for Mopar 340 engines.
I just took the time to measure the valve relief volume (including the centering hole) in these pistons. This value is 5.1 cc. Next I measured and calculated the volume of the dome at 0.018” deck height above the block, allowing for the chamfer at the edge, volume = 3.464 cc The net volume of the valve relief is 1.636cc. So, the net of the dome and valve relief is the equivalent of a full flat top piston with a deck height of 0.008” down the hole, for calculation purposes. With a combustion chamber volume of 72 cc and a standard Fel Pro compostion gasket thickness of 0.039”, the actual top of the piston at 0.018” above the block. the C.R. is 9.604:1. This should work fine with premium pump gas. The 340 I'm doing right now is for a restoration engine, built to factory specs as much as possible.
68 Charger 451 / 518
65 Cuda 273 / 833
04 Cummins 2500 2WD
02 Grand Caravan
[Re: mopar dave]
#2757050
03/28/20 10:41 PM
03/28/20 10:41 PM
Posts: 30,504 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Yes they are clunkers, but I had those in my 340. Ran it to 7200 many times with stock rods. Never had an issue with them and mine were .060 over. Clunkers you say ? ... spinning em UP to 7200 ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) ... gotta admit that they aren’t a Diamond piece ... but give those 2315s A BREAK ! A story about the L2315Fs .. years ago .... anyone remember Buckeye Sales ? ... my GRANDFATHER told me this story ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif) He was buying from BUGeye at jobber price and WD on others. The sales guy calls HIM up and gives him a SUPER DEAL on several lines but especially TRW ..... HE bought A TON of pistons ! and most of those were the 2315s .... If HIS memory serves ... something like 7 beans EACH !
[Re: dOc …]
#2757061
03/28/20 11:30 PM
03/28/20 11:30 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Yes they are clunkers, but I had those in my 340. Ran it to 7200 many times with stock rods. Never had an issue with them and mine were .060 over. Clunkers you say ? ... spinning em UP to 7200 ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) ... gotta admit that they aren’t a Diamond piece ... but give those 2315s A BREAK ! A story about the L2315Fs .. years ago .... anyone remember Buckeye Sales ? ... my GRANDFATHER told me this story ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif) He was buying from BUGeye at jobber price and WD on others. The sales guy calls HIM up and gives him a SUPER DEAL on several lines but especially TRW ..... HE bought A TON of pistons ! and most of those were the 2315s .... If HIS memory serves ... something like 7 beans EACH ! Your grandpappy died after the uNciViL war ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif) Did you sell them all or leave them in a building in Meeeeeeeecheeegan?? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: dOc …]
#2757076
03/29/20 01:31 AM
03/29/20 01:31 AM
Posts: 3,505 DFW
mr_340
DFW
The TRW L2316Fs I had were very thick at the top, about 1/2". You could mill them down to a 0 deck height. You could mill out the bottom of the tops and take some weight off them as well.
Floyd Lippencott IV
