Air grabber vacuum line clips #2756681
03/28/20 12:16 AM
03/28/20 12:16 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
I have two sets of under hood vacuum line clips for a 1970 roadrunner air grabber. Which color is correct? One is white and the other is amber. I believe that the amber are the correct ones and the white clips are after market. .....Any help will be greatly appreciated. Thanks
Re: Air grabber vacuum line clips [Re: Roadrunner440-6] #2756725
03/28/20 07:06 AM
03/28/20 07:06 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
White...
Just my $0.02... wink
Re: Air grabber vacuum line clips [Re: Sinitro] #2756763
03/28/20 09:35 AM
03/28/20 09:35 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
If it ain’t white, it ain’t right.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Air grabber vacuum line clips [Re: BloFish] #2756848
03/28/20 01:01 PM
03/28/20 01:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
originals were kind of an off white
