Re: Need good alignment specs*** UPDATE***
[Re: Challenger 1]
#275667
07/13/09 01:21 PM
07/13/09 01:21 PM
Posts: 1,164 Los Angeles, CA
JF_Moparts
Los Angeles, CA
I reached around the tire with it on, to access the cam bolts. I like your specs, do you have stock upper arms? If so, you might have trouble getting 3+ caster.
Mostly metric tools?
I'm running the tubular uppers from somewhere, I forgot where I got them. ![](/ubbthreads/images/graemlins/smile.gif)
[Re: autoxcuda]
#275669
07/13/09 02:30 PM
07/13/09 02:30 PM
JF_Moparts
Los Angeles, CA
With good tubular uppers, you should be able to 3+ deg positive caster. The 1/4 camber split is for road crown.
What was the name of shop did you got it aligned?
Take it to Bagge Alignment on Washington Blvd just a few blocks east of Overland. http://www.baggeandson.com/ (310)838-8485 Right accross from MGM studios.
They have been in business for over 90 years. Tom Vardon is a descendant of the original owner. The alignment guy, Paul, has been there for over 30 years. They fully understand custom and handling alignments.
My dad has been going there since the early 60's. We just had car aligned there last week. Tell them Dave Wall sent you (my Dad).
I think I have recommended them to you before.
You've got the silver 71 or the butterscotch 71? I get those two owners mixed up here on Moparts.
Butterscotch.
Yes, you have recommended them to me before. I wish I was closer to them, but I'll probably make the trip due to the quality they offer.
edit: I just made the appt!
[Re: JF_Moparts]
#275670
07/13/09 02:43 PM
07/13/09 02:43 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
What was the name of the shop you just went to. What basic area are you in. I go to shops all over So Cal.
[Re: JF_Moparts]
#275671
07/13/09 02:48 PM
07/13/09 02:48 PM
autoxcuda
So Cal
Butterscotch.
I've seen your butterscotch car at Stabile's in Hollywood and Lion's in Torrance.
[Re: autoxcuda]
#275672
07/13/09 04:28 PM
07/13/09 04:28 PM
JF_Moparts
Los Angeles, CA
Butterscotch.
Yep. Stabile's closed and I believe he opened a small private shop near the old one. These days I am taking my car to a small shop in the SF valley where old Mopars are a specialty. I've encouraged the owner to contribute to this forum.
[Re: JF_Moparts]
#275675
07/15/09 03:34 PM
07/15/09 03:34 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
What did it end up costing?
I have not paid retail in a while and have no idea what the rates are anymore.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#275676
07/15/09 03:35 PM
07/15/09 03:35 PM
JF_Moparts
Los Angeles, CA
I got a 10% discount. With the discount it was $71.
[Re: KARLN]
#275679
07/15/09 04:15 PM
07/15/09 04:15 PM
JF_Moparts
Los Angeles, CA
Jim were you able to find the source of the vibration?
Nope. I've had it for several years now, and don't know what's causing it. The front suspension was rebuilt in 2007. I have brand new tires and wheels. My driveshaft was just balanced. And I have a new alignment.
Maybe the frame is a little out of whack? Or maybe I screwed something up when I rebuilt the front suspension.
[Re: 68HemiB]
#275681
07/15/09 06:02 PM
07/15/09 06:02 PM
JF_Moparts
Los Angeles, CA
A true vibration (as opposed to a steering linkage shimmy), is not going to be caused by a frame out of whack or your "screwing something up when you rebuilt the front suspension". It is coming from a rotating component.
The vibration is only present between 57-63 mph. I feel it in the entire front end, but mainly in the steering wheel. It's less severe now that I've gotten the car aligned.
[Re: JF_Moparts]
#275682
07/15/09 07:34 PM
07/15/09 07:34 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
That sounds typical of wheel/tire balance issue
[Re: JF_Moparts]
#275684
07/16/09 02:10 AM
07/16/09 02:10 AM
autoxcuda
So Cal
I heard another shop today quote a alignment at $80.
So what did you think of Bagge? Did you mention I sent you?
Were they even phased by it being a 30 year old Mopar? Did you notice they still do on car old fashioned wheel balancing with an electric motor driven roller. One of the best ways to balance a Magnum 500 rim since they don't have a hub centric.
I drove by there today and I spotted a 57 Chevy in corner of my eye. Almost everyday they have something in there 30+ years old. I've seen bathtub Porsche's, late 50's Chrysler Ghia's, all kinds of exotics....
Did you mention to Tom about you vibration?? Did he have any suggustions? I bet it's a driveshaft angle. The longer Gear Vendors ampliphies that. I bet they offer driveshaft angle checking/correction. Call them.
Do you have any drop or aftermarket front hangers or rear shackles on you leaves?
Troy had one in his T/A and did a bunch of stuff and then finally checked and corrected the driveshaft angle.
[Re: autoxcuda]
#275685
08/27/11 12:56 PM
08/27/11 12:56 PM
Posts: 15,493 the boonies
aarcuda
the boonies
Going for another alignment today. I put in new Offset bushings, balljoints and wheel bearings and wheel bearings over the Winter.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#275686
08/28/11 01:15 PM
08/28/11 01:15 PM
aarcuda
the boonies
what a waste of time. went to 4 places and each one said they can do custom specs. said their computer doesnt go back before 1983 so there was no way they can do it. i'll need to go to the guy i went to last time but hes only open during the week
