Re: 74 360 engine detail [Re: 71vert340] #2756243
03/26/20 04:09 PM
03/26/20 04:09 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Now that we know the car. Go to the Mecum website for Kissimmee this year, the Wellborn museum sold a 72 and a 74 Charger, both sort of touched up survivor cars, should give you a few bits of info. You will have to give Mecum your e-mail in order to do the search.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(Had but now gone: 2 A12’s. 1 Hemi GTX, 3 other B-bodies, 2 other E-bodies and an A-body...a good run!)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: 74 360 engine detail [Re: Kowal] #2756306
03/26/20 09:02 PM
03/26/20 09:02 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks for the reply on the wires, as near as I can tell you are correct. I thought the change to orange was sometime in 73 and you supporting what I learned is another step to confirm that. Mecum does have my email and Thank You for the tip, I had seen that car listed, great idea and I will check it out Thanks. Terry great picture and info, it’s nice to see a b body. I can get a lot of info from that. I am surprised that air cleaner is black on a rally, I thought for sure it would have been orange. I do believe mine should be black, I’m putting together an SE, but I have been told it could have been either color. How about the negative battery cable, installed before engine paint or not? Thanks again to everyone, keep the info coming!!
Re: 74 360 engine detail [Re: 340cpe] #2756376
03/26/20 11:55 PM
03/26/20 11:55 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I replaced my negative battery cable and the old one was not painted. Was it the original? I can't say for sure. I have some old photos of my engine before I detailed it. I'll have to see if they are of any good to get details.
Terry
Re: 74 360 engine detail [Re: 71vert340] #2756664
03/27/20 09:16 PM
03/27/20 09:16 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank you sir!!!
Re: 74 360 engine detail [Re: 340cpe] #2757405
03/29/20 08:39 PM
03/29/20 08:39 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
The mecum sight was helpful thanks again for the suggestion. Does anyone know if the pvc valve was painted with the engine?
