6 bbl #2756330
03/26/20 10:48 PM
03/26/20 10:48 PM
at work
Grizzly Offline OP
Grizzly  Offline OP
at work
What is this worth? Is it of any use?
Re: 6 bbl [Re: Grizzly] #2756341
03/26/20 11:10 PM
03/26/20 11:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Fuel inlets on the wrong side - Chevy.
Re: 6 bbl [Re: Alaskan_TA] #2756343
03/26/20 11:18 PM
03/26/20 11:18 PM
Jamey Offline
Jamey  Offline
Those could be the old direct connection carbs. What’s the numbers on them? I may be interested in just the carbs?
Re: 6 bbl [Re: Jamey] #2756353
03/26/20 11:51 PM
03/26/20 11:51 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Same carbs used on a Mr. Norms GSS, they were Chevy 427 carbs because they were $10 cheaper. Sure they can be used on any six pack manifold with the right fuel lines and linkage so they have value...
JB Rhinehart, Realist
A-Body's RULE!
Re: 6 bbl [Re: Rhinodart] #2756359
03/27/20 12:11 AM
03/27/20 12:11 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Those float bowls sure ain't no kind of Chevy stuff.
Re: 6 bbl [Re: John Brown] #2756366
03/27/20 12:26 AM
03/27/20 12:26 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
That's the set up I use. Have 3 sets.
Direct Connection issued mechanical carbs.,,no those aren't Chevy carbs.
In that condition...1,200 ish. with manifold.maybe 1,500
Is that am OEM intake or over the counter issued?
They work very well.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 6 bbl [Re: 6bblFLASH] #2756380
03/27/20 01:19 AM
03/27/20 01:19 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
DP6B intake fits B block 383 or 400 CI. Not a 440 intake.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 6 bbl [Re: 70gtx440dana] #2756416
03/27/20 09:34 AM
03/27/20 09:34 AM
New York
rarefish Offline
rarefish  Offline
New York
By having power valves and accelerator pumps on the outboard carbs. This permits the proper usage of the full mechanical linkage. A "Triple Pumper"
Re: 6 bbl [Re: 70gtx440dana] #2756425
03/27/20 10:27 AM
03/27/20 10:27 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That's what I thought, a "B" engine intake. They may not be Chivvy carbs but the fuel inlet is on the same side...
A-Body's RULE!
Re: 6 bbl [Re: Rhinodart] #2756459
03/27/20 12:40 PM
03/27/20 12:40 PM
North Central USA (MN-WI area)
MuscleMopars Offline
Compare to this 440-6 unit I just picked up
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI
612-669-CARS
Go to my Moparts "Profile" to see my web site
Re: 6 bbl [Re: MuscleMopars] #2756465
03/27/20 12:48 PM
03/27/20 12:48 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Of course, yours is an OEM conventional setup.
In a performance application, the mechanical set will take its lunch money.😏
Re: 6 bbl [Re: rarefish] #2756469
03/27/20 12:59 PM
03/27/20 12:59 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
There are not power valves in the outboard carbs.
Basically a 3 piece "double pumper"
Re: 6 bbl [Re: 6bblFLASH] #2756478
03/27/20 01:33 PM
03/27/20 01:33 PM
New York
rarefish Offline
rarefish  Offline
New York
I saw the full size metering block on the outboards and had assumed that they would be equipped with a power valve. Just a guess on my behalf...
Re: 6 bbl [Re: rarefish] #2756486
03/27/20 01:54 PM
03/27/20 01:54 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
You can use them and block them so you have idle adjustment screws.
Or use the secondary blocks of a 4"corner" carb.
Re: 6 bbl [Re: Jamey] #2756624
03/27/20 08:39 PM
03/27/20 08:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The List number should be 4782 and 4783 with the 4782 being the primary (Center carb) and the secondaries being 4783's. I have run several of these setups since the mid 1970's. They work best on the bigger displacement motors But I have had them on my 340 since 1985 or so.
The linkage pictured is also the correct setup that was offered through direct connection and believe it or not Edelbrock.
The center carb was rated at 355 CFM with the outboards being 500 each. As I said they like Cubic inches to use all that air. When the secondaries open it's like another passing gear in an automatic car. LOL
Re: 6 bbl [Re: TJP] #2757272
03/29/20 03:35 PM
03/29/20 03:35 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Those carbs originally were used on fords, then Ma Mopar adapted them for their Hustle stuff. Carbs are worth about $600 before a rebuild and the manifold is about $300. Linkage $100. Just bought a complete setup for $900
1970 True V-Code 440 Six Pack, 4 speed
by tomsjack. 04/05/20 04:04 AM
Must see movie! Clark Gable racing at Indy
by Hemi_Joel. 04/05/20 02:30 AM
Hemi block engine mount
by hemienvy. 04/05/20 01:38 AM
1969 GTX convert 4 speed project wiw
by MI Mopar Works. 04/05/20 12:06 AM
Moparts Recent Posts
Alcohol Dominator question
by 69b1dart. 04/05/20 06:41 AM
by 71birdJ68. 04/05/20 06:35 AM
I need to replace 4”X 5” pattern axles 8.75
by NachoRT74. 04/05/20 06:00 AM
Why act like this?
by not_a_charger. 04/05/20 05:55 AM
