Page 1 of 3 1 2 3
Daytona clone bound for Bonneville Speed Week 2020 #2756077
03/26/20 12:56 AM
03/26/20 12:56 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
This project started as a 1970 Charger, 318 auto car that was three tires in the scrap yard and one on a banana peel. In a short 2 1/2 months last spring, I did a little sheetmetal work on it. It will house the 498" THE Block (B-block) Brodix B1 MC headed engine built for the task. Only need to go 238mph to break the record in Classic Production A class.
Day 1, JAN 3 2019, Starting build in WA - Copy (2).jpgDay 12 ends - Copy.jpg0105190929.jpg0114191741.jpg
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756078
03/26/20 01:02 AM
03/26/20 01:02 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
VERY COOL !!!!!! Please keep us posted.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756079
03/26/20 01:06 AM
03/26/20 01:06 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Special thanks to my friend Mike Hancock who invited me to share a corner of his shop in Washington and gave me a hand with some sheet metal removal, media blasting, and protective coating of the work when I finished. Special thanks also to my friend Tom Hodder who helped me with some fabrication of the roll bar (first time installing a roll bar) and some other tasks.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756080
03/26/20 01:10 AM
03/26/20 01:10 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
A few more pics of my effort last spring. My friend invited me to his shop in Washington...fortunately I live in FL so it was only a four day drive each way...and he put me up in his RV for my 57 days at 12 hours a day work!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756083
03/26/20 01:31 AM
03/26/20 01:31 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Still got quite a ways to go, as I still have to install almost all systems, but I have almost everything to get it done. Dual fire systems (engine compartment and cockpit), more bars in the cage, finish wiring, install Aeromotive fuel system, install parachute,wing, assemble nose and install, brake system, Hydramax clutch, etc. Still have to source a QA1 driveshaft. Have to modify and install the 9" rear axle with 2.47 gears. Does anyone know of a lower ratio for the 8 3/4" rear axle? Lowest I can find and have is a 2.76. Should be a piece of cake to have it finished by Speed Week 2020 which should be in August.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756085
03/26/20 01:40 AM
03/26/20 01:40 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Before you poo poo my power levels, keep in mind this is an endurance engine designed to run WOT for minutes at a time!
Dyno sheet Sept 2019 498.jpgDyno Chart 498 Sept 2019.jpg20190710_022301.jpg20190626_230406.jpg
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756088
03/26/20 01:50 AM
03/26/20 01:50 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Then there's the pile of some of the rusty metal I removed! Not sure where the inner and outer wheel houses went...but they were replaced too! I thought I could use the tail light panel, but it was just too thin and also had to be replaced. I have a 1968 Charger that is rustier!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756092
03/26/20 02:11 AM
03/26/20 02:11 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
This Daytona owned and driven by Lee Sicilio has the record currently. He had another Daytona in another class, but he crashed that one bad at 291mph or so last fall at Bonneville.
The second pic is a Barracuda with a twin-turbo 528 Hemi that was running almost 300 mph in 2016.
If you have not made it to Speed Week, you should consider going first chance you get. It is a unique and amazing event. If it doesn't rain out you will not be disappointed!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756108
03/26/20 07:53 AM
03/26/20 07:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My buddy want to get out there this year,, I guess he want to get his 200mps license,, we have a buddy that
is gonna let him drive for a few passes
wave
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Lifsgrt] #2756109
03/26/20 08:19 AM
03/26/20 08:19 AM
Pattison Texas
Pattison Texas
Awesome project, Daytona clone or real are at the top of my list, years ago I helped a friend building single cyl Turbo Buell motorcycles & he set some records, I did not get to go with him, but I had a blast building & dynoing the engines.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: CSK] #2756110
03/26/20 08:37 AM
03/26/20 08:37 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
"A little sheetmetal work"...I tip my hat to you, sir !
I would hope that steering setup has a very slow ratio ?
Hope Bonneville in general, & the salt especially, are good this year.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: topside] #2756117
03/26/20 09:13 AM
03/26/20 09:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Question.. how much throttle movement do you have on this car... my friends car has like 10" of travel so
its not all jerky as you roll into it
wave
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: MR_P_BODY] #2756122
03/26/20 09:37 AM
03/26/20 09:37 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Wow, what a project.
Good luck and keep us posted.
Only 238 mph?
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: MR_P_BODY] #2756128
03/26/20 09:44 AM
03/26/20 09:44 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have a friend who is into watching salt racing, he has been to Lake Gairdner in Australia, as well as many times to Bonneville. He talked me into going to Bonneville in 2014, the 100th anniversary and while the event was rained out, it was like a huge car show, every parking lot in Wendover was full of every type of vehicle from all over the world, it was great to talk to people and see all the machines. Almost went a second time, and yes it rained out that event as well. One day I will make it to Bonneville when it doesn't rain. One thing I picked up was that running on the salt is very hard on a car, I hope when you did your restoration you sealed every crevice that salt could hide in. Most of the guys I talked too completely disassemble a car after every race to clean and prevent corrosion. I have been drag racing since 1974, and I must say the salt racers have a passion about what they do. And the technology and craftsman ship is really something to see, I would recommend that any gearhead needs to see speed week at least once, it's a bucket list thing for me to get to see an event, that isn't rained out. It was weird to see the great salt lake as a lake, it had about 3 inches of water on it as far as you could see.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: jwb123] #2756136
03/26/20 10:34 AM
03/26/20 10:34 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Great job and very cool build. When I had my heart attach in 1999 while going to cardiac rehab classes an older lady noticed the racing shirt I had on and told me about her sons salt flats car. We talked for the next several weeks about racing and every time she told me about her son her eyes lit up. She was so proud of him. Goodluck and please keep us updated.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: pittsburghracer] #2756150
03/26/20 11:14 AM
03/26/20 11:14 AM
moparx Offline
moparx  Offline
great fab work ! up up
please keep the updates coming !
beer
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: moparx] #2756189
03/26/20 01:30 PM
03/26/20 01:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Very cool. I have seen plenty of engine stuff for sure and more than enough drag cars(doesn't get old btw)but this is something unique and very cool, at least to me. Cant wait to se the finished product. Bonneville is something that has always intrigued me and I have thought about it many times. For now Ill keep trying to go 200 in a 1/4 with an NA Mopar.. Best of luck with it and look forward to seeing more.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Al_Alguire] #2756229
03/26/20 04:23 PM
03/26/20 04:23 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Speed week is on my bucket list!
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: Quickrunner] #2756239
03/26/20 04:56 PM
03/26/20 04:56 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Only 238 , huh ?
Best wishes on your effort.........or should I say
efforts , since you have to back it up too.
This is super cool.
Cracking the two ton mark is bucket list stuff.
Chasing a record is getting serious.
Re: Daytona clone bound for Bonneville Speed Week 2020 [Re: tubtar] #2756275
03/26/20 07:55 PM
03/26/20 07:55 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Well plan to check that bucket list thing this year fellas! If the weather holds and this Covid-19 thing is done, it should be a hoot. I will let you guys know if I'll make it. I guarantee it is worth the trip.
Now, where does this happen-
I met my friend Mike Hancock and his crew in 2013 on Thursday evening while attending a fact finding visit for my project. Se met in a grocery store when I asked him an access question. Long story short, on Tuesday after spending some time visiting and helping out a little, he offered me to take his car for my Rookie Run (up to 150mph), which I did. It's an initial licensing run. He then says they have time for one more run, if I wanted to. Silly question...so I ran 160mph for 3 miles and gained my Class C LSR license!!
2014 and 2015 rained out, then Mike called and asked if we were coming out in 2016. I wasn't planning to attend, then Mike says "if you guys come out, I'll get you over 200mph!" I said let me get tickets! Ran193mph to license up to Class B...then a subsequent run with someone else driving broke the engine. At this event, early in the week, transmission had to come out. He says they were going home, as they were all too old to remove the trans on the salt. I said, I can do that, no need to go home! We fixed it, with the help of George Poteet's (Speed Demon) Tig welder (Troy Trepanier), eho welded the ring gear back onto the flywheel, wished us well, and then I went 193mph. What racing event habe YOU been to where this kind of thing happens? Come on out and join the fun! Come for the first weekend and all the car shows, no telling how long we will have the opportunity to run on the salt!
Page 1 of 3 1 2 3
