74 360 engine detail #2752013
03/14/20 09:39 PM
03/14/20 09:39 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Looking for some pictures of a 74 360 for proper detailing. Any help would be appreciated. I did search it and found great info from Scott Harms but it was for a 71 and probably not accurate for the 72 and up small blocks. Thanks!!
Re: 74 360 engine detail [Re: 340cpe] #2752072
03/15/20 09:09 AM
03/15/20 09:09 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Here are some pics of my 74 Duster360 . . . Some the changes I made : right hand side 340 exhaust manifold, 90 deg. oil filter adapter, dual snorkel air cleaner from 400/440 . . .
Re: 74 360 engine detail [Re: a12rag] #2752371
03/15/20 09:46 PM
03/15/20 09:46 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Is this original other than the changes that you mentioned? I am working on a b-body and looking for items like,color of Water pump bolts attaching power steering and alternator brackets, choke coil detail, any carb detail etc. etc. like I said earlier Scott Harms had excellent photos of a 71 but like everyone knows it seems when you get 72 and up the interest seems to fade off a bit particularly in the detail department. Thank You and if you could get a few shots on the front, top and sides of the engine it would be great!!
Re: 74 360 engine detail [Re: 340cpe] #2752463
03/16/20 08:55 AM
03/16/20 08:55 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I have a 74 Charger 360 Rallye but the engine was pulled and rebuilt in 1990. If you're looking for things like paint marks, etc. then I can't help you there. I did just install an NOS Carter TQ on it with all original markings. This car had a lot of dealer installed items on it such as A/C which changed some things.
Terry
Re: 74 360 engine detail [Re: 340cpe] #2752474
03/16/20 09:17 AM
03/16/20 09:17 AM
a12rag Offline
a12rag  Offline
Sorry, I have sold the car a few years ago, so don't have any other pics . . . . as for original, the original engine had been rebuilt (probably had 70k miles on the rebuild when I sold the car), so water pump had been changed, but all brackets were original, TQ was original, although I had rebuilt it a couple of times . . .
Re: 74 360 engine detail [Re: a12rag] #2752587
03/16/20 03:59 PM
03/16/20 03:59 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's a photo of the Carter TQ before installation. It's installed on the engine but has yet to be filled with gas.
Terry
Re: 74 360 engine detail [Re: 71vert340] #2752691
03/16/20 09:18 PM
03/16/20 09:18 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Does anyone know if exhaust manifolds were installed when the engine was painted? Were all the water pump bolts painted engine color, then removed to install the pwr steering and alternator brackets? Is fan spacer black or natural aluminum? Are the plug wires orange? These are some of the questions I had @nd Thanks!
Re: 74 360 engine detail [Re: 340cpe] #2754344
03/21/20 09:07 PM
03/21/20 09:07 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Also were all the air cleaners orange for the 360 in 74? It is a four barrel.
Re: 74 360 engine detail [Re: 340cpe] #2754607
03/22/20 02:41 PM
03/22/20 02:41 PM
a12rag Offline
a12rag  Offline
Yes
Re: 74 360 engine detail [Re: a12rag] #2755237
03/23/20 08:50 PM
03/23/20 08:50 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
A12 I am assuming it is yes to the air cleaner, any help with the other questions I had in the previous post?
Re: 74 360 engine detail [Re: 340cpe] #2755391
03/24/20 10:23 AM
03/24/20 10:23 AM
a12rag Offline
a12rag  Offline
Correct - air cleaner color. Uhh, my memory is too fuzzy to respond with any certainty to your questions . . . I am gonna go out on limb and say the water pump bolts were painted engine color, but the power steering pump bolts were black or black phospate??? Maybe someone else could chime in on this too . . . .
Re: 74 360 engine detail [Re: a12rag] #2755406
03/24/20 10:45 AM
03/24/20 10:45 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
https://www.nicksgarage.com/aircleaner.htm
Exhaust manifolds were still on the engine before it was painted. Water pump bolts would have been in place when painted also.
Re: 74 360 engine detail [Re: burdar] #2755504
03/24/20 03:11 PM
03/24/20 03:11 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks for the help! Obviously not a very popular restoration and somewhat difficult to find the “proper” information so I certainly appreciate anything that I can find. If anyone else would have more on the detail of a 74 360 it would be great.
Re: 74 360 engine detail [Re: 340cpe] #2755555
03/24/20 06:12 PM
03/24/20 06:12 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
This should help. Was a 73 340 Challenger that I had at one time. The exhaust manifolds were from a T/A, everything else is reasonably correct. The car was in a Challenger/Cuda book (Genat's) and a magazine.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(Had but now gone: 2 A12’s. 1 Hemi GTX, 3 other B-bodies, 2 other E-bodies and an A-body...a good run!)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: 74 360 engine detail [Re: Kowal] #2755557
03/24/20 06:22 PM
03/24/20 06:22 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
There are some pictures in the Jim Schild Challenger/Cuda book. The 74 yellow cuda in there was a stunning reference restoration when seen in person, out of Detroit at the time. I think it was written up in a magazine or two if you can find it, I saw it at the Mopar Nats...probably around 2010 or something like that. The 74 had the heat switch in the radiator, the catch bottle, etc and the pictures show that. There are 5 pretty good ones. Here is the car at Mecum...
https://www.mecum.com/lots/FL0115-203335/1974-plymouth-cuda/
Re: 74 360 engine detail [Re: Kowal] #2755688
03/25/20 07:38 AM
03/25/20 07:38 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That Cuda is an older OE restoration and has a few things that I don't think are correct but overall it's a nice representation. The booster looks like a Midland Ross and should be yellow/gold zinc plated. Some 74s came with a Bendix booster that is crimped together. Those were painted black. The standoff bracket that the electronic ignition box mounts to should also be yellow/gold zinc.
The Challenger picture above has a couple things to look at as well. The dipstick handle color has been debated. Some years were black and not engine color. Not sure what 74 should be. Also, I don't believe that the negative cables were painted on the small blocks. It's hard to tell which booster style that Challenger has. If it has a Bendix, the black paint is correct.
Also, I question the yellow/gold plating on the master cylinder cap. Everyone seems to finish them that way however, look at this picture of an original owner 73 Cuda. This picture was taken around 74. It shows a black dipstick handle and no zinc plating on the master cylinder cover.
Re: 74 360 engine detail [Re: burdar] #2756048
03/25/20 09:20 PM
03/25/20 09:20 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Some great photo’s for reference, the 73 in the first picture has orange plug wires the other two do not, which is correct? I must also say through this whole post I never mentioned that I was working on a 74 B body. I am quite sure that many of these e body’s were the same. Engine is ready for paint and just thought that when assembling may as well put together properly. All the help so far has been great and will welcome anyone else’s input. Good to know there are a few people out interested in the 3’s and 4’s.
Re: 74 360 engine detail [Re: 340cpe] #2756076
03/25/20 11:52 PM
03/25/20 11:52 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's a photo I found on the internet of what appears to be an untouched 74 Charger Rallye. This is how I remember my car being when I bought it in 1986. The brackets that are black had black headed bolts. On this engine, it looks like worm screw type clamps are used on radiator hoses instead of Corbin clamps, a typical replacement over the years.
Terry
Re: 74 360 engine detail [Re: 71vert340] #2756119
03/26/20 08:24 AM
03/26/20 08:24 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
In 74 the plug wires should be orange. My personal opinion is that early 73s were still black with red boots.
Re: 74 360 engine detail [Re: burdar] #2756135
03/26/20 09:30 AM
03/26/20 09:30 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
As stated, the 1974 cars haven't received much notice until recently. Not much information on what is correct and what isn't. My 74 Charger has this same black air cleaner in the photo I posted of the red Charger Rallye although I bought an orange one and I can change it. My brake booster ( original as far as I can tell) is black. I too am trying to get mine as original as possible but it won't be perfect. Enjoy the car.
Terry
