I've never had one of those pumps apart but I would take it apart to see what is causing the motor and pump to not turn, grit,rust or? in the pump and or rust and or corrosion in the motor
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
I've used and had to fix a bunch of the old Holley Blue race 110 GPH pumps, they have thin carbon ,I don't know the proper name of the things that slide in and out to make those pump work, pieces that wear and break off, I've also had the seal between the pump and motor go bad so you had to replace the bottom pump part to make them usable again
![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
I stop using the Holley pumps and switch to BG for race only and then to Magna fuel pumps for street and strip cars
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Please let us know what you find
![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
