My 5.9 ATK kit is all SCAT cast crank and rods with KB pistons it is balanced.
Mine is 0.040" over so with the 4 inch stroke it is 410 CI and 10.25ish (Have not measured everything yet)
-Eldy NHRA Magnum Aluminum heads that are 2.02" in and 1.60" Ex but with high flow stems. Chevy 1.6:1 Rockers with guide plates. Pocket Ported and port ported just to clean up the nastys and gasket matched 1 inch in. Pre-porting were 176cc intake and 58cc combustion chambers.
-KB Hypereutitic pistons full floating pins.
-Lunati Hyd roller cam VHR12-VHR14-112, 271/279 or 219/227 @ 0.050", 0.5493" in and 0.5653" lift with my 1.6:1 rockers.
IF you are using the Magnum front timing cover get a short snout cam. I got a long snout as I will be running the fuel pump eccentric with a 78 timing chain cover.
-Eldy AirGap intake
-Shorty SS headers
-850 CFM Thermoquad
My son's desk top dyno says 420 HP and 500+ Ft torque from 1800 RPM to redline.
The Magnum blocks have large oil passages but for some reason the return from the filter to the right side lifter gallery was small and did not seem to have been finished bored from the factory. I first ran a 7/16 bit down and it was tight in a few places. I went up to a 1/2 inch 18 inch long bit and cleaned it up. #5 main cap oil hole was also smaller so it got bored to 1/2 inch.
Your engine is going into a car but just for information,Truck Magnum oil pans SUCK! 4 quarts with no baffling and all rounded corners so the oil slides around and back on the crank.
May want to check out a KEVCO oil pan and pickup. They have baffling and a crank scraper too.
EDIT per post below this: I got my heads from Mancini fully built ready to bolt on for $687 each.
https://www.jegs.com/i/Edelbrock/350/61767/10002/-1
