68 A body HP power steering hose where to buy? #2755008
03/23/20 01:04 PM
03/23/20 01:04 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Looking for a 68 Abody high pressure power steering hose. Can't find one except Rockauto for $160 !!!!! Help !?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 68 A body HP power steering hose where to buy? [Re: HemiRick] #2755025
03/23/20 01:29 PM
03/23/20 01:29 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Do you have the old hose? A NAPA store especially in a rural town can make up hydraulic hoses from your existing hose.
Re: 68 A body HP power steering hose where to buy? [Re: formula_s] #2755056
03/23/20 02:56 PM
03/23/20 02:56 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I am sure you are talking about a 340 Dart, correct? The 383 hose is tougher to find, I had to have one made for my 69 but it is not even close to the orginal. frown
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 A body HP power steering hose where to buy? [Re: Rhinodart] #2755069
03/23/20 03:28 PM
03/23/20 03:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Engine?
The 68 parts book I have lists two pressure hoses, slant six or LA engine, no listing for a 383 A body shown.
slant six PN 2891063 same for ALL bodies. This one is found on RA for cheap
LA PN 2937981 all A bodies, some B's including 383 and 440 applications as well as the LA's. This is the $160 one I bet.
RA lists quite a few for a 69 A with a 383, maybe that can work?
Re: 68 A body HP power steering hose where to buy? [Re: Sniper] #2755082
03/23/20 03:49 PM
03/23/20 03:49 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is the original hose from my 69 383 Dart...
A-Body's RULE!
Re: 68 A body HP power steering hose where to buy? [Re: Rhinodart] #2755087
03/23/20 03:56 PM
03/23/20 03:56 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The $160 hose looks pretty close to the 383 hose, the ones listed for a 69 383 look nothing like it. Of course you look at the slant six hose and it is the same...
A-Body's RULE!
Re: 68 A body HP power steering hose where to buy? [Re: Rhinodart] #2755092
03/23/20 04:05 PM
03/23/20 04:05 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
It's a 273 engine....my hose has fittings/ends on BOTH ends like the lower one in the top pic and upper one in the 2nd pic.
It's not the rubber part of the hose that's leaking, but where the end connects to the box there's a drip. Tightening the connection does not stop it. I;ve taken it apart and inspected the metal flare and seat and they look fine.
Take care,
Rick
Re: 68 A body HP power steering hose where to buy? [Re: HemiRick] #2755103
03/23/20 04:43 PM
03/23/20 04:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Are you saying they have female flare fittings on each end?
Got a pic?
Re: 68 A body HP power steering hose where to buy? [Re: Sniper] #2755108
03/23/20 04:50 PM
03/23/20 04:50 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Quote
Yes
Take care,
Rick
Re: 68 A body HP power steering hose where to buy? [Re: HemiRick] #2755122
03/23/20 05:16 PM
03/23/20 05:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pump usually has an inverted flare and the box has a male flare. Some A-body boxes have a 90° flare fitting.
Re: 68 A body HP power steering hose where to buy? [Re: John_Kunkel] #2755134
03/23/20 05:38 PM
03/23/20 05:38 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The big block A-Body has the 90 degree fitting, the small blocks and slants do not. I actually have bought that 90 degree fitting at a parts store out of a Dorman cabinet before. Here is a pic of the hose I had made that is still on my steering box.
A-Body's RULE!
Re: 68 A body HP power steering hose where to buy? [Re: Rhinodart] #2755146
03/23/20 05:58 PM
03/23/20 05:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The pump end should be a male flare fitting, screws right into the pump. I wonder if the pump is wrong? Or someone added a fitting to it?
Re: 68 A body HP power steering hose where to buy? [Re: John_Kunkel] #2755162
03/23/20 06:51 PM
03/23/20 06:51 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
My car has the 90 degree fitting pictured above....it's dripping off the nut, that tightens the end of the hose at the box......I have removed and inspected both the flare and the fitting....and see no problem....but it's still dripping.....
Take care,
Rick
Re: 68 A body HP power steering hose where to buy? [Re: HemiRick] #2755198
03/23/20 08:22 PM
03/23/20 08:22 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I believe I had a 67 Dart GT convertible with the 273 4-bbl that had the fitting also. There should be a copper washer under the fitting that screws into the sector. I don't know if that is where yours is leaking, but mine leaked there until I got a new washer. shruggy
A-Body's RULE!
Re: 68 A body HP power steering hose where to buy? [Re: Sniper] #2755200
03/23/20 08:24 PM
03/23/20 08:24 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The pump is the original, I am the second owner and the hose I showed above is the original also. Same pump, sector, and hose I have seen on other 69 big block power steering A-Body's I have owned and judged over the years.
A-Body's RULE!
Re: 68 A body HP power steering hose where to buy? [Re: Rhinodart] #2755219
03/23/20 09:14 PM
03/23/20 09:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not talking about a BB A body. The pump used on the 273 is only used on 273's and 318's according the the FSM.
He has a 273. The steering box end is a female flare attached to that 90 degree fitting you mentioned, though on a non BB A body it's not a 90 degree one. The parts manual does show a different part number for a BB A body than all the rest.
The steering pump housing is designed to take a male flare connection with no additional fittings required. The 68 FSM has a section on replacing the Discharge Fitting Ferrule if needed, that ferrule is what seals the male flare fitting on the hose to the pump. The parts book only shows one pump for all A bodies, a .96" unit.
It makes me wonder is someone installed a pump from something else and found a hose to make it work? Or put a fitting in the pump that is not supposed to be there making the OP think he can't find the right hose?
Maybe some pics from the OP will help sort it out?
Re: 68 A body HP power steering hose where to buy? [Re: Sniper] #2755253
03/23/20 10:29 PM
03/23/20 10:29 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Should have pics of both ends of current hose in the morning. Thanks for the help For the most part this a very original unmolested car......
Take care,
Rick
Re: 68 A body HP power steering hose where to buy? [Re: HemiRick] #2755499
03/24/20 03:58 PM
03/24/20 03:58 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
I was wrong about the connection at the pump....it's a male.
In the 2nd pic it's dripping off of the fitting.....onto the pump, you can see a little wet spot.
Take care,
Rick
Re: 68 A body HP power steering hose where to buy? [Re: HemiRick] #2755526
03/24/20 05:07 PM
03/24/20 05:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'd try and see if someone could trim the line back a little and reflare the it. Maybe an A/C shop.
Re: 68 A body HP power steering hose where to buy? [Re: stumpy] #2755528
03/24/20 05:11 PM
03/24/20 05:11 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Thats a good idea! I have a flaring tool.
Take care,
Rick
