Re: Best head gasket for iron block with aluminum heads
[Re: fastmark]
#2754980
03/23/20 12:08 PM
03/23/20 12:08 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Up to around 500-550hp or so, I’m perfectly happy with the 8519’s.
[Re: fast68plymouth]
#2754997
03/23/20 12:41 PM
03/23/20 12:41 PM
Posts: 4,666 Wichita
GY3
Wichita
Cometics here and never an issue.
I've even pulled it apart and reused them once.
[Re: GY3]
#2755032
03/23/20 01:49 PM
03/23/20 01:49 PM
Posts: 3,916 usa
lewtot184
usa
[Re: DusterKid]
#2755063
03/23/20 03:09 PM
03/23/20 03:09 PM
Posts: 20,156 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Be careful with the Stealth head and big block Edelbrock heads as the firering Overhangs the chamber. This is why a lot of us started using the Felpro marine gasket which worked great. I’m in the shop and can’t check the number but it was something like 11059.
[Re: MR_P_BODY]
#2755079
03/23/20 03:47 PM
03/23/20 03:47 PM
Posts: 20,156 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I sure wished my net would work out in my shop but the distance and a metal building say... nope What kind of a cell phone do you have? If it is “hot spot” capable you can run your laptop off of it. I do it sometimes but usually have Spotify on my cell phone playing music through my stereo.
[Re: pittsburghracer]
#2755095
03/23/20 04:15 PM
03/23/20 04:15 PM
fast68plymouth
So. Burlington, Vt.
The early Stealth heads indeed had some chamber overhang issues.
The ones I’ve seen in recent years have been fine with 8519’s. But I always check it on any heads I’m installing.
I don’t ever use a 1009 on any 440 or 400 blocks. Ive seen several examples of them getting torched when the fire ring slips inside the chamfer at the top of the bore.
The 8519 doesn’t have this problem.
The marine gasket should also be good.
Cometics will work fine as well, but on this type of mild street application, IMO..... they don’t work any “better”.
[Re: MR_P_BODY]
#2755098
03/23/20 04:27 PM
03/23/20 04:27 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I sure wished my net would work out in my shop but the distance and a metal building say... nope What kind of a cell phone do you have? If it is “hot spot” capable you can run your laptop off of it. I do it sometimes but usually have Spotify on my cell phone playing music through my stereo. My phone barely works out there.. I have to be next to the only window in the shop Sounds like you need to run a Cat5e or Cat6 cable out and put a second wifi router out there. Then just use a ethernet cable from the house router to a RJ-45 jack on both ends of the cable. Done this 100's of times for ADSL customers when I was working.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: MR_P_BODY]
#2755129
03/23/20 05:31 PM
03/23/20 05:31 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I sure wished my net would work out in my shop but the distance and a metal building say... nope If your shop is on the same electric power supply as the house modem, try a power line ethernet adapter. https://www.youtube.com/watch?v=ywQeJCa3jl8
[Re: fastmark]
#2755147
03/23/20 06:00 PM
03/23/20 06:00 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Been using Mr Gasket MLS for 5 yrs on my 512 with no issues. I run Edelbrock heads and have 11.5 cr. If I remember right there are 3 different bore sizes and all are .040.
Ok
