Re: 68 A body HP power steering hose where to buy?
[Re: HemiRick]
#2755533
03/24/20 05:31 PM
03/24/20 05:31 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're absolutely sure the leak is at the flare, try a flare gasket.
[Re: John_Kunkel]
#2755554
03/24/20 07:11 PM
03/24/20 07:11 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Even better idea I had no idea they made these !!
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: John_Kunkel]
#2756261
03/26/20 06:21 PM
03/26/20 06:21 PM
HemiRick
Memphis
I got that exact part # copper gasket and its too big.....by a good bit. Do they make them smaller than 1/4?
To answer my own question Yes they make 3/16 and some of these arrived today and look like they will fit.
[Re: HemiRick]
#2758431
04/01/20 02:51 PM
04/01/20 02:51 PM
Posts: 847 Avondale AZ
Prodart440
Avondale AZ
What is the thread size on the 90 degree elbow? I need to pick one up. Thanks!!
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#2758560
04/01/20 06:54 PM
04/01/20 06:54 PM
HemiRick
Memphis
The 3/16 flare gasket was the right size but it did not stop my drip, removed line and cut off and reflared and that stopped the drip, but now from messing w it, it was leaking from the 90 fitting. Removed it and replaced the rubber o ring where it screws into the pump and this fixed the last leak.
I did not see the above question till after it was back together again. Sorry.
