Best head gasket for iron block with aluminum heads #2754978
03/23/20 12:03 PM
03/23/20 12:03 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I need a .040 head gasket for an iron block 440 with stealth heads. Can’t go any thinner. What gives the best results? I’ve heard some talk the Cometics may leak some. What about a felpro blue or maybe the better felpro gasket out there. I have new heads and a fresh cut deck.
Re: Best head gasket for iron block with aluminum heads [Re: fastmark] #2754980
03/23/20 12:08 PM
03/23/20 12:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Up to around 500-550hp or so, I’m perfectly happy with the 8519’s.
Re: Best head gasket for iron block with aluminum heads [Re: fast68plymouth] #2754997
03/23/20 12:41 PM
03/23/20 12:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Cometics here and never an issue.
I've even pulled it apart and reused them once.
'63 Dodge 330
11.19 @ 121 mph
Re: Best head gasket for iron block with aluminum heads [Re: GY3] #2755032
03/23/20 01:49 PM
03/23/20 01:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
fel-pro 8519.
Re: Best head gasket for iron block with aluminum heads [Re: lewtot184] #2755049
03/23/20 02:36 PM
03/23/20 02:36 PM
Originally Posted by lewtot184
fel-pro 8519.
iagree
I've used a bunch of them on many B and RB motors with a lot of different brand aluminum heads up
Re: Best head gasket for iron block with aluminum heads [Re: Cab_Burge] #2755057
03/23/20 02:56 PM
03/23/20 02:56 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My vote would be for Cometic. I always used the real thin .018-.020 steel shim gaskets. Had to go to thicker ones and tried felpro ones and had some leaks. Switched to Cometics on it and it's been fine every since.
Re: Best head gasket for iron block with aluminum heads [Re: DusterKid] #2755063
03/23/20 03:09 PM
03/23/20 03:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Be careful with the Stealth head and big block Edelbrock heads as the firering
Overhangs the chamber. This is why a lot of us started using the Felpro marine gasket which worked great. I’m in the shop and can’t check the number but it was something like 11059.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best head gasket for iron block with aluminum heads [Re: pittsburghracer] #2755072
03/23/20 03:29 PM
03/23/20 03:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I sure wished my net would work out in my shop but the distance and a metal building say... nope
wave
Re: Best head gasket for iron block with aluminum heads [Re: MR_P_BODY] #2755079
03/23/20 03:47 PM
03/23/20 03:47 PM
PA.
"Little"John
"Little"John
PA.
wave
What kind of a cell phone do you have? If it is “hot spot” capable you can run your laptop off of it. I do it sometimes but usually have Spotify on my cell phone playing music through my stereo.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Best head gasket for iron block with aluminum heads [Re: MR_P_BODY] #2755081
03/23/20 03:48 PM
03/23/20 03:48 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the fel-pro 1009 is the problem gasket. the 8519 fire ring doesn't hang into the bore.
Re: Best head gasket for iron block with aluminum heads [Re: pittsburghracer] #2755086
03/23/20 03:54 PM
03/23/20 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
My phone barely works out there.. I have to be next to the only window in the shop
wave
Re: Best head gasket for iron block with aluminum heads [Re: pittsburghracer] #2755095
03/23/20 04:15 PM
03/23/20 04:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
The early Stealth heads indeed had some chamber overhang issues.
The ones I’ve seen in recent years have been fine with 8519’s.
But I always check it on any heads I’m installing.
I don’t ever use a 1009 on any 440 or 400 blocks.
Ive seen several examples of them getting torched when the fire ring slips inside the chamfer at the top of the bore.
The 8519 doesn’t have this problem.
The marine gasket should also be good.
Cometics will work fine as well, but on this type of mild street application, IMO..... they don’t work any “better”.
Re: Best head gasket for iron block with aluminum heads [Re: MR_P_BODY] #2755098
03/23/20 04:27 PM
03/23/20 04:27 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
wave
wave
Sounds like you need to run a Cat5e or Cat6 cable out and put a second wifi router out there. Then just use a ethernet cable from the house router to a RJ-45 jack on both ends of the cable. Done this 100's of times for ADSL customers when I was working.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Best head gasket for iron block with aluminum heads [Re: Dave_J] #2755101
03/23/20 04:37 PM
03/23/20 04:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt mean to disrupt Marks post... its not that much to just walk back into the house to
use the net
wave
Re: Best head gasket for iron block with aluminum heads [Re: MR_P_BODY] #2755129
03/23/20 05:31 PM
03/23/20 05:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
wave
If your shop is on the same electric power supply as the house modem, try a power line ethernet adapter.
https://www.youtube.com/watch?v=ywQeJCa3jl8
Re: Best head gasket for iron block with aluminum heads [Re: John_Kunkel] #2755141
03/23/20 05:48 PM
03/23/20 05:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks.. the wife will research it
wave
Re: Best head gasket for iron block with aluminum heads [Re: fastmark] #2755147
03/23/20 06:00 PM
03/23/20 06:00 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Been using Mr Gasket MLS for 5 yrs on my 512 with no issues. I run Edelbrock heads and have 11.5 cr. If I remember right there are 3 different bore sizes and all are .040.
Ok
