clear coating a new gas tank #2754832
03/23/20 12:28 AM
03/23/20 12:28 AM
montreal,quebec,canada
buzz440 Offline OP
buzz440  Offline OP
Hi all. I just bought a brand new gas tank for my 69 Bee and was thinking about clear coating it before installing it. I would like to protect that nice new shiny finish...... has anyone clearcoated their tank ? if so please post the results and what products you used.
Later, BUZZ
Re: clear coating a new gas tank [Re: buzz440] #2754930
03/23/20 10:27 AM
03/23/20 10:27 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I never did and never will.
I hit it with WD 40 every now and then.
Ron
Re: clear coating a new gas tank [Re: RJS] #2754969
03/23/20 11:33 AM
03/23/20 11:33 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i would not. maybe rpm instead?
Re: clear coating a new gas tank [Re: chrisf] #2754970
03/23/20 11:37 AM
03/23/20 11:37 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Did that once many years ago - and it discolored if it got any fuel on it.
Re: clear coating a new gas tank [Re: buzz440] #2755007
03/23/20 01:04 PM
03/23/20 01:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I polished out the zinc coating on my new tank with steel wool and coated it with Dupont Chroma clear coat, still looks the same 16 years later, zero issues with finish.... use quality products/equipment no spray can crap
Mike
Re: clear coating a new gas tank [Re: DAYCLONA] #2755714
03/25/20 09:52 AM
03/25/20 09:52 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Mike
Looks great. Did you do anything with the straps? Getting ready to install a tank on my Plymouth
Re: clear coating a new gas tank [Re: 65pacecar] #2755835
03/25/20 02:02 PM
03/25/20 02:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Straps were stainless steel....
Re: clear coating a new gas tank [Re: DAYCLONA] #2756021
03/25/20 08:25 PM
03/25/20 08:25 PM
buzz440 Offline OP
buzz440  Offline OP
would the Eastwood 2k matte or satin clear work...... it is catalyized so it should resist gas and be tough enough to resist scratching. I should have bought the stainless steel version of this tank but was afraid that it would have been to shiney. I would like to do the chroma - clear but couldn.t be bothered mixing up so little just to do the tank............ you said you used steel wool to scuff the tank , my tank is brand new out of the box, do I still have to rub it down with the steel wool ?
Later, BUZZ
Re: clear coating a new gas tank [Re: buzz440] #2756035
03/25/20 09:00 PM
03/25/20 09:00 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I always heard that clear coat was porous and that it would still oxidize under the clear. I know people have clear coated drive shafts after blasting them and they started rusting under the clear.
inherited a 69 roadrunner from my grand pop.
