Re: 1/10ths difference on ratios?
[Re: Moparmal]
#2754037
03/21/20 04:22 AM
03/21/20 04:22 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Mal , At 3690lbs my plymouth ran 11.30 with 3.91 . Went 4.1 ran 11.18
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2754150
03/21/20 12:17 PM
03/21/20 12:17 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
you may not loose at all. Way too much missing information to know your outcome.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Moparmal]
#2754157
03/21/20 12:26 PM
03/21/20 12:26 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
My old pump gas Duster ran within 1/10 second using ratio from 3.55, 3.73,3.91, 4.10 and finally 4.30. Traction and fuel supply will determine how much your car and motor like or don't like that ratio change. Your deal is 4.7 % ratio change so it may not change your results at the track at all What RPM are you shifting at now? BB or SB motor?
[Re: Moparmal]
#2754202
03/21/20 02:36 PM
03/21/20 02:36 PM
Posts: 11,497 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What you would accomplish is slow the engine down a few hundred RPM at the top end and take away a half point of SLR, assuming a 3 speed automatic. That might help reduce wheel spin on a marginal track.
[Re: Moparmal]
#2754289
03/21/20 06:35 PM
03/21/20 06:35 PM
tex013
Sydney,Australia
Mal Isnt Heathcote faster in one lane than the other ? Have you run Calder or Portland ?
Tex
PS . Biggest change/improvement at that level was getting quality converter . Went from 4200-5000 very noticable
[Re: tex013]
#2754309
03/21/20 08:02 PM
03/21/20 08:02 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
With a 4000 converter you probably won't notice a thing.
68 Barracuda Formula S 340
