RPM intake fit under b body 383 without mod? #2753384
03/19/20 08:54 AM
03/19/20 08:54 AM
Indiana
68_661charger Offline OP
Indiana
Ive googled this a ton and didnt get a clear answer. Will a RPM intake fit on a 383 in a 68 Charger with the stock unsilenced air cleaner without a drop base? No hood pad.... Car is apart so I cant do the hood and play dough trick.
Re: RPM intake fit under b body 383 without mod? [Re: 68_661charger] #2753404
03/19/20 10:44 AM
03/19/20 10:44 AM
Wi.
old_racer Online content
old_racer  Online Content
Wi.
it fits on my son's 68 RT, but the RT has a hood bulge.
Re: RPM intake fit under b body 383 without mod? [Re: old_racer] #2753451
03/19/20 01:02 PM
03/19/20 01:02 PM
Indiana
Indiana
Ok. Should fit with a 383 vs 440
Re: RPM intake fit under b body 383 without mod? [Re: 68_661charger] #2753472
03/19/20 02:01 PM
03/19/20 02:01 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Not the exact same but, I fit one under the hood of my 69 Road Runner with the stock un-silenced air cleaner housing but, I did have to put a shorter filter in it to make it work. Even with the shorter filter, it was close. I never slammed the hood due to fear of outtie dents; I would close it and push down to ensure it was latched. Never had an issue though.
Although you mentioned not using one, I later put a drop base in and used the stock filter size.
Even later than that, I switched to a DP4B intake and use all the stock stuff now. The DP4B is about 3/4" higher than the factory intake which, will go back on the car at some point.
I'm interested in the FAST class so; I've slowly been shooting myself in the foot performance wise. I've just been curious to see the effects of the changes and have been doing them in steps backwards.
Re: RPM intake fit under b body 383 without mod? [Re: 68_661charger] #2753809
03/20/20 12:51 PM
03/20/20 12:51 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
It fits in my 67 Belvedere low block with the flat hood but I do have to use drop base air cleaner.
Re: RPM intake fit under b body 383 without mod? [Re: 68_661charger] #2754430
03/22/20 09:16 AM
03/22/20 09:16 AM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
This is for a 67 Charger, but must be similar...
https://www.forbbodiesonly.com/mopa...nd-still-using-stock-air-cleaner.113170/
Re: RPM intake fit under b body 383 without mod? [Re: STROKIE] #2754439
03/22/20 09:36 AM
03/22/20 09:36 AM
Indiana
Indiana
Thanks for the info. No big deal but surprised a drop base is needed on the 383. 440 must be so much worse.
