SB STROKER BALANCING
#2753412
03/19/20 11:13 AM
03/19/20 11:13 AM
Posts: 604 TN
1DGEMAN
TN
I have a 72 Duster 340 with matching numbers engine. It needs a rebuild. I was thinking of putting a 4.00 stroker in it. Has any one ever had the assembly balanced with the original 72 dampner? It isa 4sp car. Thanks, Rod
Real Men shift for themselves
Re: SB STROKER BALANCING
[Re: MR_P_BODY]
#2753461
03/19/20 01:24 PM
03/19/20 01:24 PM
Posts: 604 TN
1DGEMAN
TN
If your thinking of a 4" stroke then you dont need to check if your current crank is forged(74 340 was a cast crank so your balancer will be for a cast crank.. just something to think about Maybe I didn't phrase the question correctly. It is a cast crank 72 and up were cast. I was thinking I should keep the stock balancer to maintain the stock look.
[Re: 1DGEMAN]
#2753481
03/19/20 02:26 PM
03/19/20 02:26 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
You can use the stock 340 external balanced flywheel and dampener if you want I built a 340 4 inch forged steel crankshaft build for 9secondphil years ago, I used all neutral balanced stock stuff, his was a 727 car so no flywheel. I had Automotive Balancing in South Gate do the balancing on that job Only you, Gene, Bob M and few others would notice the difference in the balancers
[Re: 1DGEMAN]
#2753574
03/19/20 05:56 PM
03/19/20 05:56 PM
Posts: 4,206 New York
polyspheric
New York
You can, but you shouldn't. Why? It's 48 years old, and the rubber that does the job is nothing like what the factory put there. It cannot work the same way, and if it shears internally it goes bang.
Boffin Emeritus
[Re: polyspheric]
#2753600
03/19/20 07:13 PM
03/19/20 07:13 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
You can, but you shouldn't. Why? It's 48 years old, and the rubber that does the job is nothing like what the factory put there. It cannot work the same way, and if it shears internally it goes bang. Factory balancers were marginal pieces when new. It goes in the .02 $ per pound pile in my garage.
[Re: 1DGEMAN]
#2754080
03/21/20 09:05 AM
03/21/20 09:05 AM
Posts: 3,395 Pa
Hot 340
Pa
Are you going to use a cast stroker crank? If so, just externally balance it with your oddball 340 damper (if its a factory cast counterweighted 340 damper), as I think its silly to throw mallory metal into a cheap casting anyway. If its a forged stroker, throw a good damper on good parts.
[Re: 1DGEMAN]
#2754190
03/21/20 01:59 PM
03/21/20 01:59 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I have a 72 Duster 340 with matching numbers engine. It needs a rebuild. I was thinking of putting a 4.00 stroker in it. Has any one ever had the assembly balanced with the original 72 dampner? It isa 4sp car. Thanks, Rod Another course of action to consider....I pulled my number's matching block out of my '70 440-6 stick car and stored it safely in my basement. Then I built a 493" RB with ported Indy EZ's and a solid roller, which is way more fun on the street. If it ever grenades, I won't have lost the number's block.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
