1971 Dart Swinger found in SC field
#2752459
03/16/20 09:36 AM
03/16/20 09:36 AM
Posts: 8 Palatka, FL
SW_Florida
Palatka, FL
Found this 71 Dart Swinger (LH23C1Rxxxxxx) sitting in a field in SC for just over 3 years and surprisingly it held up well.
It has odd options I have not seen in previous Darts I have came across like this:
* Kelsey Hayes (manual) disc brakes * 8-3/4 rear end (assuming 3.23 open) * Manual pump wiper squirter * /6 225 w/904
Why put an 8-3/4 and KH discs for a /6?
It just struck me as an odd combination.
1971 Dodge Dart Swinger (current 528" Big block swap project) 1966 Plymouth Barracuda Formula S 273 4-spd (3) 1966 Barracuda parts cars 2007 Dodge Ram 1500 Laramie 5.7 Hemi 2019 Dodge Charger GT
Re: 1971 Dart Swinger found in SC field
[Re: autoxcuda]
#2752494
03/16/20 11:06 AM
03/16/20 11:06 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
I've seen this too so perhaps it isn't as odd as one would think.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: autoxcuda]
#2752515
03/16/20 12:19 PM
03/16/20 12:19 PM
Posts: 22,786 Bitopia
jcc
Bitopia
Be seen other 71 swingers similarly optioned that came with 8 3/4.
Used to see them in the junkyards like that. I even pulled an 8 3/4 out of one.
Does it have A/C too? And /or rimblow.
There a package that has like rimblow, remote mirror, vinyl top, trim, p/s, that seems to go with a lot of 8 3/4 on 71 swingers. Maybe that plus disks. So that was a "489" 8.75", or did they also make a small pinion version?
[Re: jcc]
#2752547
03/16/20 01:59 PM
03/16/20 01:59 PM
SW_Florida
Palatka, FL
There a package that has like rimblow, remote mirror, vinyl top, trim, p/s, that seems to go with a lot of 8 3/4 on 71 swingers. Maybe that plus disks. So that was a "489" 8.75", or did they also make a small pinion version? It is a 741 case, but do not know gear ratio or if it is a SG, yet.
[Re: SW_Florida]
#2752552
03/16/20 02:34 PM
03/16/20 02:34 PM
jcc
Bitopia
I thought 741's were phased out before 71?
[Re: Neil]
#2752570
03/16/20 03:51 PM
03/16/20 03:51 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
I know a guy who bought a slant 6 duster project car and it came with an 8.75 axle.
I know another person with a slant 6 1972 scamp and it has Kelsey hayes disc brakes. It also has factory ac and non-tinted windows, which seems odd. Those were just the optional 72 disk brakes. Any A-body What I have seen in 72 cars is a K-member they is half 72 and half 73. The upper half is 68-72 style biscuit motor mounts. The lower side was 73-76 pass thru sway bar style This was on a 72 disk brake /6 Abody. I assume this was a transition deal between the 72 and 73 change over. I think this happened with 69 to 70 body’s also.
[Re: autoxcuda]
#2752576
03/16/20 04:10 PM
03/16/20 04:10 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This was originally a Canadian built /6 ,904,8 3/4, 3.23 sure grip,disc brakes,front sway bar,am/fm radio,factory air, and rim blow wheel.When I bought it in 1979 it had 10,287 original miles and plastic covers still on seats.Put in 340 and 727 from a wrecked 68 GTS,never should have sold it. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
[Re: autoxcuda]
#2752761
03/17/20 08:03 AM
03/17/20 08:03 AM
Posts: 3,934 Nova Scotia Canada B2Y 1E4
SANDYinNS Canada
There a package that has like rimblow, remote mirror, vinyl top, trim, p/s, that seems to go with a lot of 8 3/4 on 71 swingers. Maybe that plus disks. I agree semed to be a common package I looked at one recently at the Turlock CA swap meet . If it has a rim blow wheel pretty good chance it has an 8.75 axle however disk brakes are a wild card some have some don't.... 318's or slant 6 318 seems to be more common with this package.
Sandy in Nova Scotia formerly drdodge340 68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute -76 feather duster-76 duster-77 street van - 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
[Re: rustbuckett68]
#2752855
03/17/20 02:52 PM
03/17/20 02:52 PM
Posts: 5,360 Planet Earth
RoadRunnerLuva
Planet Earth
My '72 Duster was built with the Kelsey-Hayes manual disc brakes, and 8.75 rear axle, and was originally a 318 2bbl car with A/C.
Plymouth Makes It!
[Re: RoadRunnerLuva]
#2752931
03/17/20 08:32 PM
03/17/20 08:32 PM
Posts: 11,084 Berlin, N.J.
abodyjoe
Berlin, N.J.
It just struck me as an odd combination. a lot more then you would think came through like that. did it have a rim blow wheel too? probably had one originally. i parted one set up the same way. knew a guy with a 4 door set up like that too..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: SANDYinNS Canada]
#2752934
03/17/20 08:37 PM
03/17/20 08:37 PM
abodyjoe
Berlin, N.J.
If it has a rim blow wheel pretty good chance it has an 8.75 axle not too sure about that.. over the years i've seen a lot of 71 darts with a rimblow but no 8 3/4.
