Rear main seal for eng with vacuum pump #2751438
03/12/20 11:45 PM
03/12/20 11:45 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
Ive been searching and can’t find a good double lip main seal for mopar bb meant for engine pulling vacuum. What are you guys using and where can i get it from. I searched for Tritec ptfe double lip seal that some guys here recommended on other posts, but they do not make one for 2 piece bb mopar , that i saw listed. I am going thru alot of work to try and make this engine sealed, and hate to use just a standard felpro seal that really is designed for crankcase under pressure.
Thanks for any help.
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751443
03/13/20 01:33 AM
03/13/20 01:33 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
the seal tri tec makes for the second gen.426 is a 3 piece seal (double lip) works great, last motor I used the seals on (both jesel seal and rear main) pulled 21" at Idle with total seal rings and a 3 vein moroso vacuum pump...….T-30501 is the part number for the rear main seal
Re: Rear main seal for eng with vacuum pump [Re: boatracer572] #2751458
03/13/20 07:53 AM
03/13/20 07:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Check with:
Patterson Elite Performance
Mailing Address: PO BOX 338, Augusta, KS 67010
Shipping Address: 920 Industrial Rd., Augusta, KS 67010
Phone: 316-775-7771
Fax: 316-775-7774
email: info@patterson-elite.com
They stock these seals and I am sure they could get anything you needed if they did not have it in stock.
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751463
03/13/20 08:57 AM
03/13/20 08:57 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
this is the one i use. I make around 11 inches of vacuum at idle with a stock timing chain cover and a old moroso 3 vane pump. proior to changing the seal i made 4 inches.
http://www.fastfishautoparts.com/Performance-Engine-Seals.html
Joe
edit looking at boatracers seal it's the same thing as fastfish for 1/2 the cost!!!
FYI it's a one piece seal you slice and RTV back together, works great.
Without Data, you’re just another guy with an opinion.
Re: Rear main seal for eng with vacuum pump [Re: sr4440] #2751520
03/13/20 12:17 PM
03/13/20 12:17 PM
New York, USA
New York, USA
Thanks....i just ordered that seal Boatracer listed from Tritec. Now i can finish this engine build. Thanks very much. And thanks for that lead 340Cuda. Ill keep that contact in mind for the future.
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751549
03/13/20 01:28 PM
03/13/20 01:28 PM
Do you have a link or contact info on the company you bought them from help
Re: Rear main seal for eng with vacuum pump [Re: Cab_Burge] #2751582
03/13/20 04:15 PM
03/13/20 04:15 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751584
03/13/20 04:23 PM
03/13/20 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just turned the stock seal backwards on my R3 engine
wave
Re: Rear main seal for eng with vacuum pump [Re: sr4440] #2751702
03/13/20 10:18 PM
03/13/20 10:18 PM
Thanks for the help up
Re: Rear main seal for eng with vacuum pump [Re: sr4440] #2751712
03/13/20 10:41 PM
03/13/20 10:41 PM
New York, USA
New York, USA
Yep....thats the one above.
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751728
03/13/20 11:47 PM
03/13/20 11:47 PM
San Jose Ca.
San Jose Ca.
glad I could help.... most important use no silicone on the seal to the block.... nicest seal I have ever used.....
Re: Rear main seal for eng with vacuum pump [Re: boatracer572] #2751740
03/14/20 12:57 AM
03/14/20 12:57 AM
New York, USA
New York, USA
Great. Thanks for that tip. Btw, is the teflon (i think) seal on the Jesel belt drive cover the hot ticket for these applications, or is there a better designed seal meant for crankcase vacuum that i should sub in there?
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751806
03/14/20 11:36 AM
03/14/20 11:36 AM
moparx Offline
moparx  Offline
why can't that seal be used on an engine with out a vacuum pump ?
beer
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751829
03/14/20 12:21 PM
03/14/20 12:21 PM
San Jose Ca.
San Jose Ca.
The tritec seals for the jesel belt drive are the same seals used by pro stock teams, and sold by places like Paterson,scmidt,sonnys..exc.exc. racing engines,,, jesel sells the tritec seals and marks them up big time...… tritec jesel double lip seal numbers are: (T-15942 ) crank seal
( T-13561 ) cam seal for BBM
care must be taken on the cam seal while pushing seal on cam hub to make sure the lip doesn't roll.standard jessel seals work good to around 20" of vacuum if your looking for more these tritec double lip seals are the ticket... I run 23" in my motor with a vacuum regulator. could run more if I so desired.....
Re: Rear main seal for eng with vacuum pump [Re: moparx] #2751831
03/14/20 12:24 PM
03/14/20 12:24 PM
San Jose Ca.
San Jose Ca.
beer
its designed to seal with vacuum
Re: Rear main seal for eng with vacuum pump [Re: boatracer572] #2751915
03/14/20 04:29 PM
03/14/20 04:29 PM
New York, USA
New York, USA
Thanks, Boatracer. Appreciate the advice. Im hoping for 12-15” but i might use that seal in the Jesel cover for the future. That is one beautiful, boat!! Must be insane to race that.
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2751933
03/14/20 05:26 PM
03/14/20 05:26 PM
San Jose Ca.
San Jose Ca.
thanks...the combo works really well as a 1280+hp... 160 mph bracket boat.....a pair of air plate stops under the carbs and delay box to activate the clutch make sure were consistent.
Re: Rear main seal for eng with vacuum pump [Re: boatracer572] #2752794
03/17/20 10:50 AM
03/17/20 10:50 AM
moparx Offline
moparx  Offline
beer
Thank You. up now i know.
beer
Re: Rear main seal for eng with vacuum pump [Re: moparx] #2753182
03/18/20 03:53 PM
03/18/20 03:53 PM
New York, USA
New York, USA
Boatracer572....you have a pm.
Re: Rear main seal for eng with vacuum pump [Re: Chargerfan68] #2753269
03/18/20 08:38 PM
03/18/20 08:38 PM
San Jose Ca.
San Jose Ca.
got it and sent one back
