Re: Best Big block stroker?
[Re: MR_P_BODY]
#2752274
03/15/20 06:31 PM
03/15/20 06:31 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I probably had the lowest form of a stroker RB in existence.... low shift point, it preferred a 4.10 gear, and got my Mirada into the 9’s. It was boring and like driving a tractor I’d love to have port fuel injection on my small block. Would be an expensive endeavor, but I’d love to have a flat stock style hood on my car ....but I’m a cheap mopar guy so carbs it is! (FI vs CARB! .....it’s like the new moparts tube K topic!! ) I got the Holley HP unit.. have MPFI and pretty much all the bells and whistles... love it so far.. still learning all the different things it will do,, got it on my Rampage I for one have been around long enough to remember the issues you had with it when you switched over. Thankfully you found the right guy to get you straightened out. Many don’t and sell it for 50% face value.
[Re: pittsburghracer]
#2752305
03/15/20 07:51 PM
03/15/20 07:51 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
.....and that’s why I run carbs and ancient non programmable ignitions etc on my car. While I can appreciate the technology available today (Grid would be sweet!), it would probably be just one more thing to go “wrong” for me at the track. My Racepak has given me enough grief! At least I don’t “need” it for the car to perform.
[Re: J_BODY]
#2752327
03/15/20 08:35 PM
03/15/20 08:35 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
I can't resist,,,, I LOVE my Street car with EFI, my carb was very well tuned for street strip, this Hilborn efi is AWESOME. no carb can do what this does.
[Re: AndyF]
#2752446
03/16/20 08:49 AM
03/16/20 08:49 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I'd start with a 4.25 crank and Trick Flow 240 heads and go from there. Find a set of pistons that give you 9.50 to 10.0 for compression and then select rods that fit. I recommend a hyd roller cam for a street/strip type of engine, maybe something around 240@050. If you have the space I'd use a Trick Flow intake and then top it off with a Holley Sniper setup and a Holley Hyperspark distributor. An engine like that should make at least 600/600 for hp and torque and be very easy to drive on the street. I have a copy of your book so dog-eared that I have to buy another. Best engine book I have read. I was also thinking of the Hyperspark and sniper. That would make a neat combination I think. Thanks. If I updated that book today I would add a whole chapter on EFI and would highly recommend that everyone ditch their carbs and switch to a Sniper. I hate to see people spending $12,000 for a new 500 inch stroker engine and then wearing it out in a few thousand miles because their double pumper dumps so much extra fuel into the engine. I have an engine in the shop right now that was ruined by running rich. The customer said he only had 500 miles on it but it is wore out. He is switching to EFI. I could not agree more. My business has become very busy now with the Sniper installs. My 512 is a totally different animal now with the Sniper and timing control.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: Dragula]
#2752457
03/16/20 09:26 AM
03/16/20 09:26 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
We have built both 400/512 and 440/512's and one 440/526.....All were 440Source....We have built a lot of them....The 512 is a beast over a 496, and so is the 526...You want tire frying killer power....Go big...We have also noticed the cap walk with the 440 is better than the 400....I always thought it would be the opposite. All of are's are done with girdles and good parts...All are kept to 6700rpm or less..
The one we have not done is a 440/543....A 4.5" crank is a big crank in a stock block.....I would love to hear feedback on one of these question, I have a aftermarket "b" block, what is the biggest stroke crank i can get to fit with a 55mm cam? Can you get a 4.5 crank to fit? I would love to have a 572 Thanks Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2752532
03/16/20 01:09 PM
03/16/20 01:09 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
I would say it depends on which rods your using and which size rod journals your using, a forged steel BB Chevy H beam rod might fit where a aluminum Mopar hemi rod might not I'm thinking of having a 4.5 stroke crankshaft made with either 2.00 or 2.100 rod journal sizes and use a BME custom aluminum rod to work in a pump gas street 572 C.I. motor
