Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2752122
03/15/20 12:49 PM
03/15/20 12:49 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Dont know your budget but if your lucky the heads may just need a valve job and new springs. If you have the $$ by all means get some new heads. I will embark on a 360 engine build in the future and I have decided I do not want to risk a flat tappet cam. Many have no problems but enough people across all MFGR spectrums have had bad experiences with the modern flat tappet stuff even though they followed every rule during break in. Converting to roller valve train on a mopar is approx $1100 plus. ($350 cam $350 lifters $100 pushrods $300 adj rocker arms.)
Keep old mopars alive.
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2752123
03/15/20 12:54 PM
03/15/20 12:54 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or
https://www.summitracing.com/parts/slp-l2355f30
just a tad lower than the KB236s
Re: 1978 440 Performance Upgrade ideas??? [Re: NachoRT74] #2752164
03/15/20 02:37 PM
03/15/20 02:37 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
X 99 on the six pack pistons
Re: 1978 440 Performance Upgrade ideas??? [Re: moparmatt] #2752553
03/16/20 02:36 PM
03/16/20 02:36 PM
Oklahoma City, Oklahoma
MrMayhem Offline
MrMayhem  Offline
MY suggestion based on 2 motors I built on a super tight budget: This combo makes a ton of torque and sounds awesome!
Hughes Whiplash cam: http://www.hughesengines.com/Index/...2ggTXVzY2xlIENhciBjYW1z&partid=30173
Eddy RPM intake, Holley 850 DP. For an even better increase in power, buy a set of E-Street heads to increase the Compression about 1 point.
Runs like a raped ape in my truck on 87 gas
