Rear main seal for eng with vacuum pump
#2751438
03/12/20 11:45 PM
03/12/20 11:45 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Ive been searching and can’t find a good double lip main seal for mopar bb meant for engine pulling vacuum. What are you guys using and where can i get it from. I searched for Tritec ptfe double lip seal that some guys here recommended on other posts, but they do not make one for 2 piece bb mopar , that i saw listed. I am going thru alot of work to try and make this engine sealed, and hate to use just a standard felpro seal that really is designed for crankcase under pressure.
Thanks for any help.
Re: Rear main seal for eng with vacuum pump
[Re: Chargerfan68]
#2751443
03/13/20 01:33 AM
03/13/20 01:33 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
the seal tri tec makes for the second gen.426 is a 3 piece seal (double lip) works great, last motor I used the seals on (both jesel seal and rear main) pulled 21" at Idle with total seal rings and a 3 vein moroso vacuum pump...….T-30501 is the part number for the rear main seal
[Re: Chargerfan68]
#2751463
03/13/20 08:57 AM
03/13/20 08:57 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
this is the one i use. I make around 11 inches of vacuum at idle with a stock timing chain cover and a old moroso 3 vane pump. proior to changing the seal i made 4 inches. http://www.fastfishautoparts.com/Performance-Engine-Seals.htmlJoe edit looking at boatracers seal it's the same thing as fastfish for 1/2 the cost!!! FYI it's a one piece seal you slice and RTV back together, works great.
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2751520
03/13/20 12:17 PM
03/13/20 12:17 PM
Chargerfan68
New York, USA
Thanks....i just ordered that seal Boatracer listed from Tritec. Now i can finish this engine build. Thanks very much. And thanks for that lead 340Cuda. Ill keep that contact in mind for the future.
[Re: sr4440]
#2751712
03/13/20 10:41 PM
03/13/20 10:41 PM
Chargerfan68
New York, USA
Yep....thats the one above.
[Re: Chargerfan68]
#2751728
03/13/20 11:47 PM
03/13/20 11:47 PM
boatracer572
San Jose Ca.
Yep....thats the one above. glad I could help.... most important use no silicone on the seal to the block.... nicest seal I have ever used.....
[Re: boatracer572]
#2751740
03/14/20 12:57 AM
03/14/20 12:57 AM
Chargerfan68
New York, USA
Yep....thats the one above. glad I could help.... most important use no silicone on the seal to the block.... nicest seal I have ever used..... Great. Thanks for that tip. Btw, is the teflon (i think) seal on the Jesel belt drive cover the hot ticket for these applications, or is there a better designed seal meant for crankcase vacuum that i should sub in there?
[Re: Chargerfan68]
#2751829
03/14/20 12:21 PM
03/14/20 12:21 PM
boatracer572
San Jose Ca.
The tritec seals for the jesel belt drive are the same seals used by pro stock teams, and sold by places like Paterson,scmidt,sonnys..exc.exc. racing engines,,, jesel sells the tritec seals and marks them up big time...… tritec jesel double lip seal numbers are: (T-15942 ) crank seal ( T-13561 ) cam seal for BBM care must be taken on the cam seal while pushing seal on cam hub to make sure the lip doesn't roll.standard jessel seals work good to around 20" of vacuum if your looking for more these tritec double lip seals are the ticket... I run 23" in my motor with a vacuum regulator. could run more if I so desired.....
[Re: moparx]
#2751831
03/14/20 12:24 PM
03/14/20 12:24 PM
boatracer572
San Jose Ca.
why can't that seal be used on an engine with out a vacuum pump ? its designed to seal with vacuum
[Re: boatracer572]
#2751915
03/14/20 04:29 PM
03/14/20 04:29 PM
Chargerfan68
New York, USA
The tritec seals for the jesel belt drive are the same seals used by pro stock teams, and sold by places like Paterson,scmidt,sonnys..exc.exc. racing engines,,, jesel sells the tritec seals and marks them up big time...… tritec jesel double lip seal numbers are: (T-15942 ) crank seal ( T-13561 ) cam seal for BBM care must be taken on the cam seal while pushing seal on cam hub to make sure the lip doesn't roll.standard jessel seals work good to around 20" of vacuum if your looking for more these tritec double lip seals are the ticket... I run 23" in my motor with a vacuum regulator. could run more if I so desired..... Thanks, Boatracer. Appreciate the advice. Im hoping for 12-15” but i might use that seal in the Jesel cover for the future. That is one beautiful, boat!! Must be insane to race that.
[Re: Chargerfan68]
#2751933
03/14/20 05:26 PM
03/14/20 05:26 PM
boatracer572
San Jose Ca.
The tritec seals for the jesel belt drive are the same seals used by pro stock teams, and sold by places like Paterson,scmidt,sonnys..exc.exc. racing engines,,, jesel sells the tritec seals and marks them up big time...… tritec jesel double lip seal numbers are: (T-15942 ) crank seal ( T-13561 ) cam seal for BBM care must be taken on the cam seal while pushing seal on cam hub to make sure the lip doesn't roll.standard jessel seals work good to around 20" of vacuum if your looking for more these tritec double lip seals are the ticket... I run 23" in my motor with a vacuum regulator. could run more if I so desired..... Thanks, Boatracer. Appreciate the advice. Im hoping for 12-15” but i might use that seal in the Jesel cover for the future. That is one beautiful, boat!! Must be insane to race that. thanks...the combo works really well as a 1280+hp... 160 mph bracket boat.....a pair of air plate stops under the carbs and delay box to activate the clutch make sure were consistent.
[Re: boatracer572]
#2752794
03/17/20 10:50 AM
03/17/20 10:50 AM
Posts: 19,355 north of coder
moparx
why can't that seal be used on an engine with out a vacuum pump ? its designed to seal with vacuum Thank You. now i know.
[Re: moparx]
#2753182
03/18/20 03:53 PM
03/18/20 03:53 PM
Chargerfan68
New York, USA
Boatracer572....you have a pm.
