71 Rallye Dash wiring HELP ********UPDATE FIXED********* #2749907
03/07/20 03:51 PM
03/07/20 03:51 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I had my dash out to install restored woodgrain pieces and do a repaint.
After I re-installed I now have my amp gauge going complete discharge when I turn the key forward or to accessory.
I pulled one fuse at a time to no avail.
Re-inspected and fuse block wiring for any shorts etc...
Re-installed my old (working) original voltage limiter
Unplugged all accessories one at a time.
Re-installed my old (working) blinker harness
Interior lights work, dash lights work, 4 ways work, in other words anything that doesn't require the key to be turned on including clock .
Can anyone post the backside of a 71-4 Rallye dash to see if I attached something wrong??? This is far from the first time I've done this job and even took the dash assembly back out and onto the bench for a 2nd. time to no avail.
Thanks in advance Ron
Re: 71 Rallye Dash wiring HELP [Re: RJS] #2749911
03/07/20 04:09 PM
03/07/20 04:09 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Here is my 71 Charger Rallye dash with clock. Low mile car just removed a few weeks ago. If you need other pics let me know.
Re: 71 Rallye Dash wiring HELP [Re: T2R9] #2749942
03/07/20 06:44 PM
03/07/20 06:44 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Thank you very much!!!!
I found the problem and it was operator error!!!
I've taken many apart and put back together so why take a second or two and take a picture I told myself before disassembly!!!
Didn't factor in my being 60 years old now and I had a black wire w/white tracer on the voltage limiter that is a cluster ground!!!
Makes perfect sense now: If you put a ground wire on a V.limiter's ign. side you will get a large discharge when you turn the key on!!!!!
I'm a real Richard on this one!!
Ron
Re: 71 Rallye Dash wiring HELP [Re: RJS] #2750104
03/08/20 12:29 PM
03/08/20 12:29 PM
central il.
second 70 Offline
second 70  Offline
central il.
Thank-you for your honesty and reminding us all that we're not perfect and double check our work because we all make mistakes.
Re: 71 Rallye Dash wiring HELP [Re: second 70] #2750129
03/08/20 12:56 PM
03/08/20 12:56 PM
moparx Offline
moparx  Offline
happy that the cause was found before the "magic smoke" escaped from the harness ! up
beer
Re: 71 Rallye Dash wiring HELP [Re: moparx] #2750163
03/08/20 03:00 PM
03/08/20 03:00 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I really did expect to find a melted mess when I took it apart but someone was looking out for me this time!!
Ron
